Did a stall, and engine almost quit.
motoadve
PostPosted: Mon May 13, 2019 4:05 pm    Post subject: Did a stall, and engine almost quit. Reply with quote
This stall was no different than all the ones I have practiced before, clean power off, at recovery when I added power (very smoothly as I always do) engine sputtered and stumbled, then continued fine.
During descend to pattern when I reduced power, engine was running a bit rougher than usual , not terrible but I noticed it, 5 MP and 2000 RPMs.
Added some power at pattern and it smoothed out also at low power settings for the landing was smooth.
Any theories?
www.Backcountry182.com
Cessna 182 P
CJ -6
Harv
PostPosted: Tue May 14, 2019 7:11 am    Post subject: Re: Did a stall, and engine almost quit. Reply with quote
I had similar issues with my CJ, happened after about 30mins flight time and adding power smoothed it out. Problem became worse during subsequent flights and it turned out to be failing mag coils. I couldn’t repeat the issue on the ground even after prolonged warmup and ground running.
How long into your flight before this occurred?
I removed the old mag coils, had them both rewound and it now runs stronger than ever.
Just my thoughts.
Maybe do a few more over airfield flights for plus 30 mins and see if it happens again.
richard.goode(at)russiana
PostPosted: Tue May 14, 2019 7:30 am    Post subject: Did a stall, and engine almost quit. Reply with quote
That is a classic coil problem which will only manifest itself when the engine is hot and the heat has totally penetrated the magneto and, more specifically the coil. It is very difficult to get the magneto sufficiently hot to have this partial failure on the ground. And the only solution is to change the coil!
RICHARD GOODE AEROBATICS
Rhodds Farm, Lyonshall, Hereford, HR5 3LW, UK
Tel: +44 (0)1544 340120 Fax: +44 (0)1544 340129
e-mail: richard.goode(at)russianaeros.com
www.russianaeros.com
WORLD LEADERS IN RUSSIAN SPORTING AIRCRAFT & ENGINES
In partnership with Aerometal Kft, Hungary.
dsavarese0812(at)bellsout
PostPosted: Tue May 14, 2019 10:09 am    Post subject: Did a stall, and engine almost quit. Reply with quote
If I may ask, who rewound the coils?
Thx
Dennis
Just my thoughts.
http://forums.matronics.com/viewtopic.php?p=489220#489220
Harv
PostPosted: Tue May 14, 2019 11:13 pm    Post subject: Re: Did a stall, and engine almost quit. Reply with quote
In the UK we have some specialist firms who have been rewinding coils for something like 75years (family run business) and they handled it.
Contact me off list if you need any more details.
PostPosted: Wed May 15, 2019 12:22 am    Post subject: Did a stall, and engine almost quit. Reply with quote
Yes, after over 30 years' experience with these engines, and particularly
the magnetos/coils, we investigated all the significant UK companies engaged
in magneto overhauls, and chose the one we felt was the best. They designed
a new coil for us three years ago, and importantly with an external
capacitor/condenser. The reason for this is that the primary cause of
failure is the capacitor overheating and degenerating with age, and of
course this is made worse since it is normally sitting inside a coil of hot
wire!
So we now make new coils with a high-technology Panasonic capacitor bonded
to the outside of the coil so it remains cooler, but still fits comfortably
inside the magneto. We have sold many to customers all over the world with
100% satisfaction!
Richard
PostPosted: Wed May 15, 2019 3:21 am    Post subject: Did a stall, and engine almost quit. Reply with quote
Thanks Richard. Now that I know where to go, you can be sure when folks ask me, I'll be sending them your way.
Dennis
On Wednesday, May 15, 2019, 4:25:30 AM EDT, Richard Goode <richard.goode(at)russianaeros.com> wrote:
--> Yak-List message posted by: "Richard Goode" <richard.goode(at)russianaeros.com (richard.goode(at)russianaeros.com)>
wire!
100% satisfaction!
Richard
e-mail: richard.goode(at)russianaeros.com (richard.goode(at)russianaeros.com)
motoadve
PostPosted: Mon Jun 10, 2019 5:19 am    Post subject: Re: Did a stall, and engine almost quit. Reply with quote
Was not the mags.
Intake tube on cyl 5 had a big hole, the drain tube broke and was sucking air.
Fixed that.
Now engine runs smoother than ever.
Cessna 182 P
CJ -6
PostPosted: Mon Jun 10, 2019 5:27 am    Post subject: Did a stall, and engine almost quit. Reply with quote
That certainly will do it!
Dennis
On Monday, June 10, 2019, 9:21:38 AM EDT, motoadve <motoadve(at)racsa.co.cr> wrote:
--> Yak-List message posted by: "motoadve" <motoadve(at)racsa.co.cr (motoadve(at)racsa.co.cr)>
Was not the mags.
Fixed that.
Cessna 182 P
CJ -6
http://forums.matronics.com/viewtopic.php?p=489574#489574
he many List utilities such as List Un/Subscription,
h=====================
= --> http://www.matronics.==
PostPosted: Mon Jun 10, 2019 5:52 am    Post subject: Did a stall, and engine almost quit. Reply with quote
You don't mention the kind of manifold oil drain system that was used and what actually had failed. But, in our experience, it is a mistake to use the standard Russian manifold drain plug (I have no experience of this on the Nanchang engine); drill it and tap it for an AN fitting. This is because it is relatively thin aluminium and simply not designed to be drilled and tapped. We make a much thicker plug to replace the Russian one that has much greater strength and is designed to be tapped.
Richard
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of A. Dennis Savarese
Sent: 10 June 2019 14:26
To: yak-list(at)matronics.com
Subject: Re: Re: Did a stall, and engine almost quit.
Dennis
On Monday, June 10, 2019, 9:21:38 AM EDT, motoadve <motoadve(at)racsa.co.cr (motoadve(at)racsa.co.cr)> wrote:
Was not the mags.
Fixed that.
Cessna 182 P
CJ -6
= --> [url=http://wiki.matronics.com][/url]
PostPosted: Mon Jun 10, 2019 7:36 am    Post subject: Did a stall, and engine almost quit. Reply with quote
Richard, What do you have for the small intake tube drains that appear on some engines?
Dennis
On Jun 10, 2019, at 9:52 AM, Richard Goode <richard.goode(at)russianaeros.com (richard.goode(at)russianaeros.com)> wrote:
<![endif]--> <![endif]-->
Richard
From: owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) [mailto:owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)] On Behalf Of A. Dennis Savarese
Dennis
Was not the mags.
Fixed that.
Cessna 182 P
CJ -6
PostPosted: Mon Jun 10, 2019 8:25 am    Post subject: Did a stall, and engine almost quit. Reply with quote
We change the complete intake tube – those ones with a very small hole are simply too small to fit an appropriate AN fitting.
I attach photographs of the much thicker plugs that we manufacture.
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Anthony Savarese
Sent: 10 June 2019 16:25
Richard,
Dennis
Richard
Dennis
Was not the mags.
Fixed that.
Cessna 182 P
CJ -6
 Filesize:  83.21 KB
 Viewed:  13490 Time(s)
 Filesize:  60.95 KB
 Filesize:  68.01 KB
 Filesize:  73.34 KB
PostPosted: Mon Jun 10, 2019 8:47 am    Post subject: Did a stall, and engine almost quit. Reply with quote
And you might ask why there are no locking "castelations" on our thicker nuts – the answer is simply that they are always going to be used with an oil drain tube and the tube is what prevents it unscrewing itself!
Richard
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Richard Goode
Sent: 10 June 2019 17:25
Subject: RE: Re: Did a stall, and engine almost quit.
From: owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) [mailto:owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)] On Behalf Of Anthony Savarese
Richard,
Dennis
Richard
Dennis
Was not the mags.
Fixed that.
Cessna 182 P
CJ -6
PostPosted: Mon Jun 10, 2019 11:12 am    Post subject: Did a stall, and engine almost quit. Reply with quote
Thanks Richard.
Dennis
A. Dennis Savarese
334-546-8182 (mobile)
www.yak-52.com
Skype - Yakguy1
On 6/10/2019 12:24 PM, Richard Goode wrote:
We change the complete intake tube ??? those ones with a very small hole
*RICHARD GOODE AEROBATICS***
*Rhodds Farm, Lyonshall, Hereford, HR5 3LW, UK*
Tel: +44 (0)1544 340120???? Fax:?? +44 (0)1544 340129
<mailto:richard.goode(at)russianaeros.com>
www.russianaeros.com <http://www.russianaeros.com>
*W**ORLD LEADERS IN RUSSIAN SPORTING AIRCRAFT & ENGINES***
*In partnership with Aerometal Kft, Hungary.*
[mailto:owner-yak-list-server(at)matronics.com] *On Behalf Of *Anthony
Savarese
*Sent:* 10 June 2019 16:25
*To:* yak-list(at)matronics.com
*Subject:* Re: Re: Did a stall, and engine almost quit.
Richard,
engines?
Dennis
Richard
<mailto:owner-yak-list-server(at)matronics.com>
[mailto:owner-yak-list-server(at)matronics.com] *On Behalf Of *A.
Dennis Savarese
*Sent:* 10 June 2019 14:26
*To:* yak-list(at)matronics.com <mailto:yak-list(at)matronics.com>
Dennis
Was not the mags.
sucking air.
Fixed that.
www.Backcountry182.com <http://www.Backcountry182.com>
Cessna 182 P
CJ -6
_http://www.matronics.==
<http://wiki.matronics.com>_
_
_
_
