philperry9
Posted: Wed May 01, 2019 8:39 am Post subject: Flap Motor Lube |
Is there a recommended annual lube to put on the shaft of the flap motor? Or are there other recommend lube points besides the shaft and rod-end bearing?
You’d have to think there a way to get lube on the screw drive mechanism.
Phil Perry, EAA Lifetime #834284
President, EAA Chapter 59 - Waco, Texas
EAA—The Spirit of Aviation
gengrumpy
Joined: 07 May 2013 Posts: 131 Location: Tullahoma, TN
Posted: Wed May 01, 2019 1:59 pm Post subject: Flap Motor Lube |
Phil,
I just use a little LPS2 on the shaft each year. Seems to work well for the past 12 condition inspections!
Grumpy | Quote: | On May 1, 2019, at 11:36 AM, Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)> wrote:
