Flaps actuator potentiometer
diamond
PostPosted: Tue Apr 23, 2019 2:04 pm    Post subject: Flaps actuator potentiometer Reply with quote
Hello, I’m a new happy owner of an Xs, and recently bought an Mgl efis fo upgrade my panel. I wanted that mostly to use a fuel flow and a flaps controller. (To keep an hand on the switch to move the flaps is not very secure in my mind...)
The problem is that the flap actuator doesn’t seem to have a potentiometer...This is bad because the efis needs a flaps position information...
Is someone had ever added a potentiometer or replaced the actuator?
Emmanuel
carlp101
PostPosted: Sun May 05, 2019 3:16 am    Post subject: Re: Flaps actuator potentiometer Reply with quote
Hi Emmanuel,
I fitted a slider type potentiometer to my XS to allow my Dynon Skyview EFIS to display the flap position. I've attached a picture. You can get them from suppliers like RS Components. I just drilled a small hole in the flap arm to attach the slider arm and then bonded the unit to the fuselage.
Hope this helps.
Carl
 Filesize:  1.13 MB
 Viewed:  6053 Time(s)
Rick Moss
PostPosted: Fri May 10, 2019 2:02 am    Post subject: Re: Flaps actuator potentiometer Reply with quote
I don't mean to be flippant, but is it not easier to just look at the flaps? Certainly more reliable!
carlp101
PostPosted: Fri May 10, 2019 4:48 am    Post subject: Re: Flaps actuator potentiometer Reply with quote
It is, but I wanted an indicator that I could clearly see at night and in IMC conditions because I've applied for the removal of the VFR restriction on my Europa.
