Fuel Reserve Idiot Lamp Module
vanremog
PostPosted: Fri Apr 19, 2019 10:42 am    Post subject: Fuel Reserve Idiot Lamp Module Reply with quote
Because my fuel gauges happen to be located on the right side of the panel I always felt long term that I needed something in my routine field of view on long cross country flights. I recently installed reserve idiot lights like most cars have. What you will need are two each of the following items, a little 22 AWG wire, some crimp lugs and some solder. I set my initial trip point at 190 Ohms which in my case is about 2.5gal. The module has an antibounce circuit.
https://www.spiyda.com/miniature-low-fuel-warning-light-module-2.html
I felt that the LEDs needed to be nice panel mount ones, so I used these instead of what came with the modules.
https://www.amazon.com/gp/product/B01F2GT1ME/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
The instructions were okay except for the last part of section b). Method 1 for our SW senders should be connected as described in Method 2. He has the hookup information backwards.
GV N1GV
johGrey
PostPosted: Thu Oct 24, 2019 11:18 pm    Post subject: Re: Fuel Reserve Idiot Lamp Module Reply with quote
This sounds like a very easy mod. I'll see if I can try this next weekend.
