pelletie1959(at)me.com Guest
Posted: Thu Apr 11, 2019 3:23 pm Post subject: S700-2-50 switch |
Hi,
I perform the Z-16 diagram from Bob and I use the S700-2-50 switch suggest by Bob to light the ignition and the starter contactor. I have some problems with the wiring of that switch. Somebody have a wiring diagram for that switch. And is it possible to get the same result with the S700-2-51 switch which have only 4 poles.
Daniel Pelletier
Posted: Fri Apr 12, 2019 9:46 am Post subject: S700-2-50 switch |
Not really,
I've yet thi diagram. Maybe I don't understand this diagram. When I flip the switch on the momentary, the starter contactor is on but the ignition is off. It doesn't make sense.
Daniel Pelletier
Envoyé de mon iPad
Posted: Fri Apr 12, 2019 10:57 am Post subject: Re: S700-2-50 switch |
We need more information. Do you have a Rotax 912ULS engine?
If not, what engine?
Does it have magnetos?
Can you post a picture that shows how the wires are connected?
I would use 3 separate switches like diagram Z-20.
1 momentary switch for starting.
2 separate ignition switches.
_________________ Joe Gores |
steerr(at)bellsouth.net Guest
Posted: Fri Apr 12, 2019 11:11 am Post subject: S700-2-50 switch |
That's what I did for the Hirth 3202 on my Excalibur. The two separate
ignition switches, and the pushbutton start switch, are wired so that
both ignition switches must be on for the start switch to work.
On 4/12/2019 2:57 PM, user9253 wrote:
I would use 3 separate switches:
Joe Gores
http://forums.matronics.com/viewtopic.php?p=488691#488691
This email has been checked for viruses by AVG.
https://www.avg.com
Posted: Fri Apr 12, 2019 4:56 pm Post subject: S700-2-50 switch |
I have a 912 uls. I use this setup of switch at the suggestion of Bob, see note 2 in the Z16 diagram. But there is no pattern for that type of switch in the Z16 schema. If I can find the way to plug it, I will use a distinct start button and two separate switch for ignition.
Daniel Pelletier
Envoyé de mon iPad
| Quote: | Le 12 avr. 2019 à 15:11, Bill Steer <steerr(at)bellsouth.net> a écrit :
That's what I did for the Hirth 3202 on my Excalibur. The two separate ignition switches, and the pushbutton start switch, are wired so that both ignition switches must be on for the start switch to work.
> Joe Gores
https://www.avg.com
Posted: Fri Apr 12, 2019 7:10 pm Post subject: Re: S700-2-50 switch |
Below is a drawing showing how to connect ignition switches and start switch.
40.35 KB |
6225 Time(s) |
