CJ Air Scoop
Saber369(at)comcast.net
PostPosted: Tue Apr 09, 2019 9:28 am    Post subject: CJ Air Scoop Reply with quote
Can anyone tell me the purpose of the small air scoop on the lower left side of the Nanchang? Not on all CJs... Just a few that I've seen.
Sent from Xfinity Connect Application
 Filesize:  2.6 MB
 Viewed:  6405 Time(s)
GeorgeCoy
PostPosted: Tue Apr 09, 2019 9:59 am    Post subject: CJ Air Scoop Reply with quote
I imagine it is there to keep the pilot cool when the main fan (prop) quits
in flight!.
PS
PostPosted: Tue Apr 09, 2019 10:13 am    Post subject: Re: CJ Air Scoop Reply with quote
I recognize my old CJ!
The scoop was for heat muff supply.
Phil
Phil
k7wx
PostPosted: Tue Apr 09, 2019 10:43 am    Post subject: CJ Air Scoop Reply with quote
Jon,
Mine was also one of those unusual CJs that had this same air scoop. Did not appear to serve any purpose, so I later removed it and filled in the hole.
Here is a picture taken the day it was purchased and flown to Arizona from the Bay area. The scoop is visible on the lower cowling.
Warren Hill
N464TW
Mesa, AZ
[img]cid:1D972B37-A62E-46C8-92D5-7A3FBB87C1EC[/img]
On Apr 9, 2019, at 10:28 AM, JON <Saber369(at)comcast.net (Saber369(at)comcast.net)> wrote:
Can anyone tell me the purpose of the small air scoop on the lower left side of the Nanchang? Not on all CJs... Just a few that I've seen.Sent from Xfinity Connect Application<IMG_20190406_151815756.jpg>
 Filesize:  304.8 KB
 Viewed:  6398 Time(s)
Harv
PostPosted: Wed Apr 10, 2019 1:08 am    Post subject: Re: CJ Air Scoop Reply with quote
Mine has this scoop
I also suspect it was to supply fresh air to a cabin heat exchanger mounted on the port side exhaust manifold. Mine was missing the exchanger but did come with a mixing unit located between the front and rear cockpits and there were holes in the fwd firewall on both sides down by your feet that I believe the ducting could have passed through.
