paul(at)eckenroth.com Guest
Posted: Sun Apr 07, 2019 11:18 am Post subject: Battery Contactor Voltage Drop |
What is the typical voltage drop across the poles of a healthy battery contactor. Is there a failure or aging mode where the voltage drop increases. How about typical voltage drop across the diode bridge rectifier for the essential buss. After eleven trouble free years I need to sort out some problems with my RV9A. Thanks for any information.
Paul
ceengland7(at)gmail.com Guest
Posted: Sun Apr 07, 2019 1:31 pm Post subject: Battery Contactor Voltage Drop |
On 4/7/2019 2:16 PM, Paul Eckenroth wrote:
| Quote: | What is the typical voltage drop across the poles of a healthy battery
Paul
Drop across a good contactor should be hard to measure reliably with a
regular voltmeter.
Drop across a typical silicon diode will be zero with no load, but will
be around 0.7V at any significant load.
If you have a Schottky diode (not likely, but possible), it will be
around 0.5V or less under load.
N509RV(at)eckenroth.com Guest
Posted: Mon Apr 08, 2019 7:33 am Post subject: Battery Contactor Voltage Drop |
Thanks for the information Charlie. The reason for the question is that I have 1 EFIS each on the regular buss and the E buss which show .9V difference. Does the diode degrade in a way that would increase voltage drop.
Paul
On Sun, Apr 7, 2019 at 5:34 PM Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
| Quote: | --> AeroElectric-List message posted by: Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)>
> Paul
regular voltmeter.
WIKI -
Joined: 28 Mar 2008 Posts: 1948 Location: Riley TWP Michigan
Posted: Mon Apr 08, 2019 8:03 am Post subject: Re: Battery Contactor Voltage Drop |
Paul,
The diode is fine. A voltage drop of 0.9 volts across a diode is normal. The voltage drop depends
on the diode characteristics and the current. Some power diodes will drop 1.5 volts or more.
_________________ Joe Gores |
Posted: Mon Apr 08, 2019 9:30 am Post subject: Battery Contactor Voltage Drop |
As long as the operating voltage with the alternator running is 'normal' (around 14V), I wouldn't be concerned about a 0.9V drop from primary bus across a standard diode block. If the diode is a typical 'full wave rectifier' (square metal or plastic block with 4 leads), and the source is feeding the '-' terminal and the load is on the '+' terminal, the voltage drop will be higher since the path is actually through two diodes in series. Not a big deal as long as you understand what's happening. Only time it might matter is after alternator loss, at the very end of battery life, *if* the E bus is still fed through the diode.
Charlie
On 4/8/2019 10:31 AM, Paul Eckenroth wrote:
| Quote: | Thanks for the information Charlie. The reason for the question is that I have 1 EFIS each on the regular buss and the E buss which show .9V difference. Does the diode degrade in a way that would increase voltage drop.
Paul
> Paul
regular voltmeter.
WIKI -
Posted: Mon Apr 08, 2019 2:48 pm Post subject: Battery Contactor Voltage Drop |
| Quote: | | If the diode is a typical 'full wave rectifier' (square metal or plastic block with 4 leads), and the source is feeding the '-' terminal and the load is on the '+' terminal, the voltage drop will be higher since the path is actually through two diodes in series. |
All of my drawings show power input
on an AC terminal (~) and output
on the (+). This uses only one of
the four diodes to minimize voltage
drop.
| Quote: | | Not a big deal as long as you understand what's happening. Only time it might matter is after alternator loss, at the very end of battery life, *if* the E bus is still fed through the diode. |
Correct. Your radios are 'speced' to function
to 10V or less. By the time a battery gets
down to 10v (lead acid) or 11.2v (LiFePO4)
the battery is 'used up'. This is why the
e-bus alternate feed switch is closed any
time the alternator is off line . . . which
lets the electro-whizzies suck the battery
dry.
Any time the alternator is working, voltage
drop in the normal feed diode is insignificant.
Posted: Mon Apr 08, 2019 4:30 pm Post subject: Battery Contactor Voltage Drop |
I appreciate everyone's comments. I thought I had a problem which has now evaporated.
Paul
On Mon, Apr 8, 2019 at 6:52 PM Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
| Quote: | | Quote: | | If the diode is a typical 'full wave rectifier' (square metal or plastic block with 4 leads), and the source is feeding the '-' terminal and the load is on the '+' terminal, the voltage drop will be higher since the path is actually through two diodes in series. |
drop.
dry.
