Most Electrical Failures are caused by poor workmanship
PostPosted: Thu Apr 04, 2019 6:43 am    Post subject: Most Electrical Failures are caused by poor workmanship Reply with quote
Below is a quote from an experienced repairman. It seems that most electrical
failures are due to poor workmanship, not due to the chosen architecture or
hardware. Read the complete post here:
http://www.vansairforce.com/community/showpost.php?p=1336866&postcount=67
With regards to electrically dependent aircraft, we've had 24 years
supplying and supporting them and based on tech and feedback over that time,
the #1 cause of no electrons flowing is poor wiring practices- ground and power
connections/ bad crimps, #2 is routing near sharp and hot stuff with inadequate
thermal and chafe protection, #3 poor strain relief and support. Switch gear
stuff is well down the list in causing issues.
Pick all the high dollar components you want but more important is how the
electrical system is put together.
Joe Gores
