engine cowl
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List
cdawson5854(at)shaw.ca
PostPosted: Fri Mar 29, 2019 11:28 pm    Post subject: engine cowl Reply with quote
Cardboard pattern for aluminum cowl.
Clif
Bill; "When I die I want to be cremated."
Willy; "Why?"
Bill; "It'll be my last chance at a smokin' body."
- The Matronics Pietenpol-List Email Forum -
http://www.matronics.com/Navigator?Pietenpol-List
 Filesize:  114.54 KB
 Viewed:  1894 Time(s)
 Filesize:  106.57 KB
 Filesize:  113.31 KB
 Filesize:  113.54 KB
 Filesize:  107.98 KB
 Filesize:  101.21 KB
 Filesize:  89.31 KB
jack(at)textors.com
PostPosted: Sat Mar 30, 2019 1:52 am    Post subject: engine cowl Reply with quote
Very nice Cliff!
Jack Textor
On Mar 30, 2019, at 2:26 AM, Clif Dawson <cdawson5854(at)shaw.ca (cdawson5854(at)shaw.ca)> wrote:
Clif
Willy; "Why?"
<COWL 2.JPG>
<COWL 3.JPG>
<COWL 4.JPG>
<COWL 5.JPG>
<COWL 6.JPG>
<COWL 7.JPG>
<COWL 8.JPG>
jboatri(at)emory.edu
PostPosted: Sat Mar 30, 2019 3:27 am    Post subject: engine cowl Reply with quote
Looking good!
Jeffrey H. Boatright, PhD, FARVO
Professor of Ophthalmology
Emory University School of Medicine
Core Director & Research Biologist
Atlanta VAMC Center for Visual & Neurocognitive Rehabilitation
From: <owner-pietenpol-list-server(at)matronics.com> on behalf of Clif Dawson <cdawson5854(at)shaw.ca>
Reply-To: "pietenpol-list(at)matronics.com" <pietenpol-list(at)matronics.com>
Date: Saturday, March 30, 2019 at 3:31 AM
Subject: Pietenpol-List: Fw: engine cowl
Clif
Willy; "Why?"
This e-mail message (including any attachments) is for the sole use of
the intended recipient(s) and may contain confidential and privileged
information. If the reader of this message is not the intended
recipient, you are hereby notified that any dissemination, distribution
or copying of this message (including any attachments) is strictly
prohibited.
If you have received this message in error, please contact
the sender by reply e-mail message and destroy all copies of the
original message (including attachments).
taildrags
PostPosted: Sun Mar 31, 2019 9:41 am    Post subject: Re: engine cowl Reply with quote
Clif; I really like the way it looks with the colored stock that you used. I've made mockups using poster board and cardboard, but they look cheesy compared to yours.
So where do you plan to install a heat muff for carb heat, and what about your oil filler cap/dipstick? Where will that shoot out?
Oscar Zuniga
Medford, OR
Oscar Zuniga
Medford, OR
Air Camper NX41CC "Scout"
A75 power, 72x36 Culver prop
PostPosted: Sun Mar 31, 2019 9:46 pm    Post subject: engine cowl Reply with quote
Well, the card stock ( matt board ) was a cheesy bright red so
I took the same paint as will be on the real thing and sprayed it.
( bloody cheater!Smile ). I've got two 4 by 8 sheets of free aluminum.
Guess what? It's 2/3d's the thickness I need. Sad Oh well.
So, I've been struggling with the muff. I think it will be
the same pipe material welded to the inside a rear cylinder
pipe right up under the cylinder, more or less hidden.
The filler is up behind the right rear cylinder so a little
door will have to go there.
Clif
"Boy that was a smooth landing, now everyone get ready for the speed bump!"
compared to yours.
Oscar Zuniga
Medford, OR
danoliver
PostPosted: Sun Apr 07, 2019 4:19 am    Post subject: Re: engine cowl Reply with quote
Very nice!
I couldn't help but notice your wheels. If you don't mind me asking what are they and what if any modifications did you do?
Dan O
PostPosted: Sun Apr 07, 2019 9:20 pm    Post subject: engine cowl Reply with quote
OK, they're Suzuki 19" wheels. Pic one is the original wheel. The next pic
is the inner side flange machine off, the hole milled out to be large enough
to accept the 1" flange bearing I made. The next is the hub extension I
made to increase the distance between inner and outer bearings. The next
shows the inner face of same with cutout for the wheel flange. The final
pic is the finished wheel on the 1 1/2" axle shaft.
Because my lathe/mill isn't big enough to turn the hub flange off and bore
the bearing hole, that had to be done with the milling part of the combo.
Like your own Uncle Abe said, " Give me six hours to chop down a tree
and I will spend the first four sharpening the ax."
So I spent a LOT of time setting up that mill. Twice! Smile
Clif
"I don't want to go to heaven. None of my friends are there."
Oscar Wilde
Very nice!
Dan O
http://forums.matronics.com/viewtopic.php?p=488591#488591
This email has been checked for viruses by AVG.
https://www.avg.com
 Filesize:  105.05 KB
 Viewed:  1751 Time(s)
 Filesize:  65.7 KB
 Filesize:  99.89 KB
 Filesize:  94.43 KB
 Filesize:  126.46 KB
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List All times are GMT - 8 Hours
