Covering ailerons questions.
Viperdoc
PostPosted: Sun Mar 24, 2019 12:28 pm    Post subject: Covering ailerons questions. Reply with quote
Anybody covering ailerons. The mounting points and the push rod connection points are a problem damning up. See my attached email for pictures and please give your thoughts. I need a foam that is not destroyed by MEK. Thanks
Doc
Begin forwarded message:
From: Roger Kemp <f16viperdoc(at)me.com (f16viperdoc(at)me.com)>
Date: March 23, 2019 at 7:13:39 AM CDT
Subject: Fwd: Covering ailerons
Reply-To: yak-list(at)matronics.com (yak-list(at)matronics.com)
Sent a different way after being rejected.Doc
From: "Roger Kemp M.D." <viperdoc(at)mindspring.com (viperdoc(at)mindspring.com)>
Date: March 22, 2019 at 11:22:20 PM CDT
Subject: Covering ailerons
What type foam is used for damming and adding form to the push rod attachment points on the aileron. The foam is high density. It does not dissolve when exposed to organics specifically MEK (methylethyl ketone).
[img]cid:0E244017-79F1-4E87-828A-40BD3E0DC16F[/img]
[img]cid:FAB74D12-191A-471D-AD90-DED7D9DC1ECC[/img]
[img]cid:E123C7DD-23AB-449D-917C-F60489FB1798[/img]
 Filesize:  315.3 KB
 Viewed:  1958 Time(s)
 Filesize:  347.16 KB
 Filesize:  322.68 KB
Viperdoc
