Choke
eoinmaguire(at)hotmail.co
PostPosted: Fri Mar 22, 2019 3:06 pm    Post subject: Choke Reply with quote
Hi all
Just wondering has anyone else experienced a choke that is next or near impossible to pull. I’ve installed a new choke and cables that I got from Karen, cables move fine when not connected to the carbs, each individual choke mechanism on each carb also move fine but when connected up the whole lot is very very stiff, nearly to the point of it being impossible to pull !
Any ideas ?
Kind Regards
Eoin
JonathanMilbank
PostPosted: Fri Mar 22, 2019 4:22 pm    Post subject: Re: Choke Reply with quote
Widest gentlest cable curves possible? But you've already done that, no doubt. Sorry I've nothing more inspirational to offer.
Remi Guerner
PostPosted: Fri Mar 22, 2019 11:48 pm    Post subject: Re: Choke Reply with quote
The key is to make sure the bowden cables are well lubricated. The best is to remove the cables from their sheath and lubricate full length with automotive gearbox or engine oil. Also keep the 90° elbows of the carbs well lubricated.
Remi
Ivor
PostPosted: Sat Mar 23, 2019 3:36 am    Post subject: Re: Choke Reply with quote
Or do what Bud yearling suggested and put a T handle on the cable
For more pulling power, That’s choke not women Very Happy
wdaniell.longport(at)gmai
PostPosted: Sat Mar 23, 2019 3:52 am    Post subject: Choke Reply with quote
And use a bulldog clip on the shank to keep it out while you startWill
William Daniell
LONGPORT
+57 310 295 0744
On Sat, Mar 23, 2019, 06:39 Ivor <g-iver(at)live.co.uk (g-iver(at)live.co.uk)> wrote:
--> Europa-List message posted by: "Ivor" <g-iver(at)live.co.uk (g-iver(at)live.co.uk)>
http://forums.matronics.com/viewtopic.php?p=488202#488202
pa-List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?Europa-List
WIKI -
budyerly(at)msn.com
PostPosted: Sun Mar 24, 2019 11:33 am    Post subject: Choke Reply with quote
Eoin,
I missed your email on the list.
In my troubleshooting guide I explain the choke friction problem. I did a post a few weeks ago on my T handle to add some grip to the handle and not having the knob pull off.
Please read my troubleshooting guide on line.  www.customflightcreations.com techniques section under engine related.
Lube on the cable helps, but making sure the cables are left long and loopy, see photo’s on how I run the cables, then smooth the 90 degree bent tube nice and smooth. I summarized this in the cable etiquette article attached also.
Best Regards,
Bud Yerly
Custom Flight Creations.
Sent from Mail for Windows 10
From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> on behalf of Eoin Maguire <eoinmaguire(at)hotmail.com>
Sent: Friday, March 22, 2019 7:04:59 PM
Subject: Choke
--> Europa-List message posted by: Eoin Maguire <eoinmaguire(at)hotmail.com>
Hi all
Any ideas ?
Kind Regards
Eoin
st Email Forum -
pa-List">http://www.matronics.com/Navigator?Europa-List
p; - MATRONICS WEB FORUMS -
ums.matronics.com
matronics.com
p;   -Matt Dralle, List Admin.
Throttle_and_Choke_Cable_Etiquette.pdf
 Filename:  Throttle_and_Choke_Cable_Etiquette.pdf
 Filesize:  1.34 MB
 Downloaded:  565 Time(s)
PostPosted: Tue Mar 26, 2019 1:56 am    Post subject: Choke Reply with quote
Hi all
Just a quick thanks to everyone that answered back about the sticky choke cable....seems to have improved with a long loop and lubing up the cable.
Kind Regards
Eoin
