Atten Soldering Station?
jsajpf
PostPosted: Fri Feb 22, 2019 4:25 pm    Post subject: Atten Soldering Station? Reply with quote
Anyone on the group have experience with this brand, or this model soldering station in particular:
https://hobbyking.com/en_us/atten-50w-at-937-adjustable-soldering-station-with-soldering-iron-us-plug.html
skywagon185(at)gmail.com
PostPosted: Fri Feb 22, 2019 5:03 pm    Post subject: Atten Soldering Station? Reply with quote
I have a couple of those low cost soldering units and they work fine for the smaller circuitry type of work..
On Fri, Feb 22, 2019 at 4:31 PM jsajpf <john.friday_adis(at)sbcglobal.net (john.friday_adis(at)sbcglobal.net)> wrote:
--> AeroElectric-List message posted by: "jsajpf" <john.friday_adis(at)sbcglobal.net (john.friday_adis(at)sbcglobal.net)>
http://forums.matronics.com/viewtopic.php?p=487751#487751
Electric-List" target="_blank" rel="noreferrer">http://www.matronics.com/Navigator?AeroElectric-List
_blank" rel="noreferrer">http://forums.matronics.com
WIKI -
lank" rel="noreferrer">http://wiki.matronics.com
target="_blank" rel="noreferrer">http://www.matronics.com/contribution
jimkale(at)roadrunner.com
PostPosted: Fri Feb 22, 2019 7:19 pm    Post subject: Atten Soldering Station? Reply with quote
I bought a HAKKO temp controlled station a  couple of years ago.  I immediately had trouble with it because the changeable tips don’t make good contact.  I made a minor modification to my unit and it is somewhat better, but still I get the disconnect  warning sound occasionally but tap it on the bench to get it reconnected.  Anyone else having problems with Hakko??
From: owner-aeroelectric-list-server(at)matronics.com <owner-aeroelectric-list-server(at)matronics.com> On Behalf Of skywagon185guy
Sent: Friday, February 22, 2019 7:03 PM
To: aeroelectric list <aeroelectric-list(at)matronics.com>
Subject: Re: Atten Soldering Station?
WIKI -
PostPosted: Sat Feb 23, 2019 8:02 am    Post subject: Re: Atten Soldering Station? Reply with quote
How do you keep a soldering iron tip clean and tinned?
I have a Metcal SP200 soldering station purchased from eBay. The iron tip
appears to be stainless steel or some other tin colored metal. I clean it with a
kitchen stainless steel scouring pad and tin the iron with solder. But the very tip
of the iron has a dark coating that will not melt solder. I am reluctant to use
sandpaper or other abrasive for fear of damaging the tip. How do you keep
your soldering iron tip clean and tinned?
Joe Gores
alec(at)alecmyers.com
PostPosted: Sat Feb 23, 2019 8:17 am    Post subject: Atten Soldering Station? Reply with quote
Use some liquid flux on the hot tip, then wipe it on a damp sponge or cloth.
Joe Gores
http://forums.matronics.com/viewtopic.php?p=487761#487761
cluros(at)gmail.com
PostPosted: Sat Feb 23, 2019 8:50 am    Post subject: Atten Soldering Station? Reply with quote
Hello Joe, I have attached the instructions for my Hakko. Also my electronics guy says always coat the tip with solder before turning the iron off in order to protect the tip from oxidation.
On Sat, Feb 23, 2019, 08:08 user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
Joe Gores
Electric-List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
WIKI -
 Filesize:  1.57 MB
 Viewed:  22687 Time(s)
lyleapgmc
PostPosted: Sat Feb 23, 2019 9:22 am    Post subject: Atten Soldering Station? Reply with quote
I have found that copper tips work best.  I bought an iron some years ago that had a bright plated tip.  It would not tin.  Rather than attempt to remove the plating, or whatever it was, I returned the iron.
I have an iron that has tips that are threaded.  When I need a new tip or one that has a different shape I use a short length of copper wire.  I don't remember the gauge of the wire but something like 4ga or 6ga comes to mind.  I simply cut a few threads on one end of the piece of wire and shape the other end for my needs.
Just my thoughts,
Lyle
Joe Gores
WIKI -
email(at)jaredyates.com
PostPosted: Sat Feb 23, 2019 9:37 am    Post subject: Atten Soldering Station? Reply with quote
I dampen the sponge on the base that holds the iron, and wipe the damp sponge with the hot tip. It's like deglazing a hot skillet, works great every few minutes.
On Sat, Feb 23, 2019 at 11:09 AM user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
Joe Gores
WIKI -
jonlaury
PostPosted: Sat Feb 23, 2019 9:41 am    Post subject: Re: Atten Soldering Station? Reply with quote
I've used a Hakko 888 for years and have been very pleased with the performance. Heats quickly, compact size, good temp control. I would "improve" it by having a more intuitive analog control. If I'm using it everyday, then the digital control sequences get burned into my brain and it's fine. The problem is remembering the sequences when I haven't used it for few months.
If this one bit the dust, I'd still buy another one.
PostPosted: Sat Feb 23, 2019 10:14 am    Post subject: Atten Soldering Station? Reply with quote
Copper is not a 'bad' tip material, it just
doesn't have a good service life compared to
the iron-plated copper.
Molten solder is a SOLVENT for copper . . .
this affinity for copper to disolve into
solder is what makes the critical amalgamation
at the surface which manifests in a good
'flow'.
But every time you craft a soldered joint
using a pure copper tip, some of the tip
is washed off into your finished joint.
Hence the tip must be periodically
re-shaped or even replaced.
All professional soldering iron tips are
iron plated. Like copper, iron will also
amalgam with the tin-lead solvent but
to a lesser degree in that the melting
temperature of the lead-tin-iron mix
rises more sharply. Hence the rate of
'wash off' for iron is much less and
the life of the tip is extended greatly.
But wear a little hole in the iron and
the tip will begin to disappear into
subsequent joints.
My soldering iron holders are fitted with
pads of stainless steel 'pot scrubbers'
from the local grocery or department store.
[img]cid:.0[/img]
There are copper versions of this tool
which are to be avoided for obvious
reasons. The drill for making a joint
is to pick up the iron, push it into
the scrubber a couple of strokes,
wet the tip with fresh solder, place
the wetted surface against the work-piece(s)
and the apply solder BETWEEN the iron
and the work-piece until the joining
'flows'.
 Filesize:  27.17 KB
 Viewed:  22672 Time(s)
