MAC 3 LED Trim Indicator...
Site Admin
PostPosted: Sat Feb 16, 2019 4:29 pm    Post subject: MAC 3 LED Trim Indicator... Reply with quote
Hello,
A fellow homebuilder friend of mine has a old-style three-LED (Red|Green|Red) MAC Trim Position Indicator. The Green LED was burned out, and the wires were cut off too short.
I told him I would try to replace the LED and lead wires. I got it apart without completely destroying it. But the internal wiring and polarity of the LEDs isn't that clear to me, nor is the actuation of it through a servo electronically. I'm not sure how to activate three LEDs with only three wires? (Or did there used to be four wires?)
Does anyone have a PDF schematic of the 3-LED MAC Trim Indicator that you could email to me?
Or better yet, does anyone have a spare or unused one of these they would like to sell me?
Thank you,
Matt G Dralle | Matronics | 581 Jeannie Way | Livermore | CA | 94550
 Filesize:  264.61 KB
 Viewed:  2713 Time(s)
ceengland7(at)gmail.com
PostPosted: Sat Feb 16, 2019 5:00 pm    Post subject: MAC 3 LED Trim Indicator... Reply with quote
On 2/16/2019 6:27 PM, Matt Dralle wrote:
Hello,
Thank you,
Is it accessible enough to clip-lead the LED in for testing? If so, just pick a direction. If it works, you're done. If it doesn't, reverse the leads. Assuming that the current limiting is done external to the LED itself, it won't matter if you insert it backward; it just won't light up.
Charlie
chaskuss(at)yahoo.com
PostPosted: Sun Feb 17, 2019 6:45 am    Post subject: MAC 3 LED Trim Indicator... Reply with quote
Matt, why not supply us with a close up photo or two? Often, the LED polarity can be identified by a difference in the legs of the LED. If the leads are to short to extend, could you de-solder them [one at a time] from the board and solder in new leads?
Charlie
On Sunday, February 17, 2019, 1:15:39 AM UTC, Charlie England <ceengland7(at)gmail.com> wrote:
Hello,
Thank you,
Charlie
