wynaire(at)citlink.net Guest
Posted: Mon Feb 04, 2019 7:32 pm Post subject: 🚚 ORDER UPDATE: Replacement Depo 441... |
THANKS!!! Will buy from you, again. Mike
Sent from my Galaxy Tab® S2
body { width: 100% !important; -webkit-text-size-adjust: 100% !important; -ms-text-size-adjust: 100% !important; -webkit-font-smoothing: antialiased !important; margin: 0 !important; padding: 0 0 0 !important; font-family: Helvetica, Arial, sans-serif !important; background-color:#f9f9f9} { "(at)context": "http://schema.org", "(at)type": "EmailMessage", "action": { "(at)type": "ViewAction", "url": "https://rover.ebay.com/rover/0/e11401.m43533.l7719/7?euid=8394a88601c0427ea03e770392e21cbc&bu=43187781268&loc=https%3A%2F%2Fwww.ebaycom%2Fulk%2Fvod%3Fitemid%3D302411453001%26transid%3D1598814851020%26qu%3D1&sojTags=bu=bu", "name": "Track order" }, "description": "Track order" } (at)media only screen and (min-width: 601px) { device-width { width: 584px !important } show-in-mobile { display: none !important; max-height: 0px !important; max-width: 0px !important; overflow: hidden !important; mso-hide: all; } hide-in-mobile { display: block !important; max-height: none !important; max-width: none !important; overflow: visible !important; mso-hide: none; } } (at)media only screen and (max-width: 600px) { device-width { width: 584px !important } } (at)media only screen and (max-width: 479px) { device-width { width: 304px !important; } hide-in-mobile { display: none !important; max-height: 0px !important; max-width: 0px !important; overflow: hidden !important; mso-hide: all; } show-in-mobile { display: block !important; max-height: none !important; max-width: none !important; overflow: visible !important; mso-hide: none; } div-mobile-product-image { align:center; } mobile-template-min-width { min-width: 320px !important; } mobile-cta-resize { width: 304px !important; } mobile-width-100 { width: 100% !important; } } cta-block { min-width: 103px; max-width: 300px; } cta-block a { display: block; padding: 10px 0; } cta-block td{ padding: 0px !important } (at)font-face { font-family: "Market Sans"; src: url('https://ir.ebaystatic.com/cr/v/c1/market-sans/v1.0/MarketSans-Regular-WebS.eot'); src: url('https://ir.ebaystatic.com/cr/v/c1/market-sans/v1.0/MarketSans-Regular-WebS.eot?#iefix') format('embedded-opentype'), url('https://ir.ebaystatic.com/cr/v/c1/market-sans/v1.0/MarketSans-Regular-WebS.woff2') format('woff2'), url('https://ir.ebaystatic.com/cr/v/c1/market-sans/v1.0/MarketSans-Regular-WebS.woff') format('woff'), url('https://ir.ebaystatic.com/cr/v/c1/market-sans/v1.0/MarketSans-Regular-WebS.ttf') format('truetype'), url('https://ir.ebaystatic.com/cr/v/c1/market-sans/v1.0/MarketSans-Regular-WebS.svg#MarketSans-Regular-WebS') format('svg'); font-weight: normal; font-style: normal; } (at)font-face { font-family: "Market Sans"; src: url('https://ir.ebaystatic.com/cr/v/c1/market-sans/v1.0/MarketSans-SemiBold-WebS.eot'); src: url('https://ir.ebaystatic.com/cr/v/c1/market-sans/v1.0/MarketSans-SemiBold-WebS.eot?#iefix') format('embedded-opentype'), url('https://ir.ebaystatic.com/cr/v/c1/market-sans/v1.0/MarketSans-SemiBold-WebS.woff2') format('woff2'), url('https://ir.ebaystatic.com/cr/v/c1/market-sans/v1.0/MarketSans-SemiBold-WebS.woff') format('woff'), url('https://ir.ebaystatic.com/cr/v/c1/market-sans/v1.0/MarketSans-SemiBold-WebS.ttf') format('truetype'), url('https://ir.ebaystatic.com/cr/v/c1/market-sans/v1.0/MarketSans-SemiBold-WebSsvg#MarketSans-SemiBold-WebS') format('svg'); font-weight: bold; font-style: normal; } body { width: 100% !important; -webkit-text-size-adjust: 100% !important; -ms-text-size-adjust: 100% !important; -webkit-font-smoothing: antialiased !important; margin: 0 !important; padding: 0 0 32px 0; font-family: 'Market Sans', Helvetica, Arial, sans-serif !important; background-color:#ffffff} img { display: block; text-decoration: none !important; -ms-interpolation-mode: bicubic !important; } td{word-wrap: break-word; word-break: break-word;} webkit { max-width: 100%; margin: 0 auto; } unselect-text { -webkit-touch-callout: none; -webkit-user-select: none; -khtml-user-select: none; -moz-user-select: moz-none; -ms-user-select: none; -o-user-select: none; user-select: none; } select-text { -webkit-touch-callout: default; -webkit-user-select: text; -khtml-user-select: text; -moz-user-select: text; -ms-user-select: text; -o-user-select: text; user-select: text; } body,table,td,h1,h2,h3,h4,h5,h6,p,font,a,div,span,style {font-family: Helvetica, Arial, sans-serif !important;} <![endif]--> table{mso-table-lspace:0pt; mso-table-rspace:0pt;} <![endif]--> body{ padding: 0 0 100px 0; } white-space-normal{white-space: normal !important} (at)media only screen and (min-width: 601px) { show-text-in-mobile { max-height: 0px !important; max-width: 0px !important; overflow: hidden !important; } hide-text-in-mobile { max-height: none !important; max-width: none !important; overflow: visible !important; } desktop-remove-width { width: 0 !important; } } (at)media only screen and (max-width: 479px) { hide-text-in-mobile { display: none !important; max-height: 0px !important; max-width: 0px !important; overflow: hidden !important; } show-text-in-mobile { display: block !important; max-height: none !important; max-width: none !important; overflow: visible !important; } mobile-banner-image { max-width: 309px !important; height: auto !important; } remove-float { float: none !important; } mobile-item-details-width { width: 184px !important; min-width:184px !important; height: 40px !important; } mobile-cta-resize { width: 304px !important; max-width: 304px !important; } mobile-cta-spacer { width: 50px !important; max-width: 50px !important; } mobile-remove-top-padding { padding-top: 0 !important; } mobile-remove-bottom-padding { padding-bottom: 0 !important; } mobile-remove-min-width { min-width: 0 !important; } mobile-width-100 { width: 100% !important; } mobile-image-width{ width: 112px !important; } mobile-table-width{ width:250px !important; } mobile-td-width{ width:90px !important; } mobile-width{ width:240px !important; } mobile-module-height{ height:60px !important; } mobile-cta-padding{ padding: 32px 0 16px 0 !important; } mobile-img-height{ height: 13px !important; } mobile-module-width{ width:230px !important; } mobile-mbg-img-width{ width:96px !important; } } -------- Original message --------
Date: 2019-02-04 6:17 PM (GMT-07:00)
To: wynaire(at)citlink.net
Subject: 🚚 ORDER UPDATE: Replacement Depo 441...
ETA: Fri, Feb 08. [img]https://rover.ebay.com/roveropen/0/e11401/7?euid=8394a88601c0427ea03e770392e21cbc&bu=43187781268&sojTags=bu=bu[/img] Hi Michael, your order is being shipped! <![endif]--> Check order status <![endif]--> <![endif]--> Go to site <![endif]--> <![endif]--> <![endif]--> <![endif]--> <![endif]--> <![endif]--> <![endif]--> Your order will ship to: 275 Aspen Dr
Moab, UT 84532-2947
United States
<![endif]--> --> <![endif]--> <![endif]--> <![endif]--> <![endif]--> Estimated delivery: Fri, Feb 08
