Garmin Aera660 powered from aircraft bus
John M Tipton
PostPosted: Sat Jan 26, 2019 1:42 am    Post subject: Garmin Aera660 powered from aircraft bus Reply with quote
Hi Guys
We intend to mount a Garmin Aera660 semi potable GPS into our panel using an AirGizmo mount, so far so good, with the wiring pack comes a 'cigar socket' power plug, is it OK to cut this off and connect to the aircraft bus, or does the cigar plug actually have a voltage reduction circuit inside.
Regards: John
PostPosted: Sat Jan 26, 2019 8:36 am    Post subject: Garmin Aera660 powered from aircraft bus Reply with quote
At 03:42 AM 1/26/2019, you wrote:
--> AeroElectric-List message posted by: "John M Tipton" <john(at)tiptonuk.eu>
Hi Guys
Regards: John
Appendix D of the users manual describes
this item:
[img]cid:.0[/img]
A 'bare' wire interface between the Aera660 and
ship's systems. Also, the manual speaks to an
internal, 3A fuse in the cigar-lighter plug.
This is a common connector to many automotive
add-ons. The fuse installation takes up a substantial
volume of the connector shell . . . it seems
very unlikely that it contains additional
electronics . . . a disassembly would confirm.
 Filesize:  151.57 KB
 Viewed:  4794 Time(s)
John M Tipton
PostPosted: Sat Jan 26, 2019 2:46 pm    Post subject: Re: Garmin Aera660 powered from aircraft bus Reply with quote
Hi Bob
I've managed to get hold of a Garmin GPS lead, and the plug that goes into the unit has four pins, two are dormant, the other two are 12v + & -, the cigar plug once dismantled has indeed a glass fuse link, so all good for 12v fused to the aircraft bus.
Which does raise one other question, the fuse looks like 1/4amp, how do I fuse this (and other items like 'steam gauge lighting') which have only light gauge wires, the smallest fuse available for the bus is 1amp
John
hlbartel(at)pld.com
PostPosted: Sun Jan 27, 2019 6:18 am    Post subject: Garmin Aera660 powered from aircraft bus Reply with quote
John,
I'm not sure where you live, but you should be able to go to an electronics
store and find that fuse there. When I was still at the local airport as
manager, we installed an AWOS, and the phone line to it was fused with a
1/10 amp fuse. When we installed it to protect an ISI board ($300) we no
longer blew the board at evey thunderstorm. That 1/10 amp fuse was only $2,
and much easier to replace.
Harry
N0HQG
