Pitot Static Tubing inside wing
n7188u
PostPosted: Mon Jan 21, 2019 11:28 am    Post subject: Pitot Static Tubing inside wing Reply with quote
Hello Europa Group (and Happy New Year),
I am installing the pitot/static head in my wing and noticed I don't have the tubing. Can anyone provide the type of tubing that was supplied with the kit?
Obviously Tygon is appropriate but knowing the size originally provided would help.
Best Regards and Thanks,
Chris
h&jeuropa
PostPosted: Tue Jan 22, 2019 4:58 pm    Post subject: Re: Pitot Static Tubing inside wing Reply with quote
Chris,
The original parts list shows PVC tube 3mm x 6mm. Same tube is called out in the glider wing build manual.
Jim
n7188u
PostPosted: Wed Jan 23, 2019 9:40 am    Post subject: Re: Pitot Static Tubing inside wing Reply with quote
Thanks Jim, that's what I needed.
Chris
