Pierburg fuel pump 7.2097155 - Now Facet pump
kingsnjan(at)westnet.com.
PostPosted: Mon Jan 14, 2019 5:33 pm    Post subject: Pierburg fuel pump 7.2097155 - Now Facet pump Reply with quote
Hmmm, pays to engage brain first .... if a plunger type pump didn’t have a non return valve I guess it wouldn’t be a pump!
SO, reading your question again Graham, I assume you were asking “DOES the Facet block reverse flow?”
I cannot categorically say but I am 99.9% sure it does. If it didn’t, I don’t know how it could pump. Judging by the noise it makes notwithstanding being solid state, I can only assume the noise is made by the valves opening and closing.
Cheers
Kingsley
On 15 Jan 2019, at 10:49 am, Kingsley Hurst <kingsnjan(at)westnet.com.au> wrote:
Hello Graham,
Not exactly sure what you mean by ‘reverse flow’ but whether or not it has a non return valve I don’t know sorry.
K
> On 14 Jan 2019, at 8:57 pm, Gaham Singleton <grahamsingleton(at)btinternet.com> wrote:
> Can’t remember Kingsley, is the Facet block reverse flow?
> G
