Open Barrel Crimp Tools
PostPosted: Wed Jan 02, 2019 7:35 pm    Post subject: Open Barrel Crimp Tools Reply with quote
At 06:37 PM 1/2/2019, you wrote:
--> AeroElectric-List message posted by: "blues750" <den_beaulieu(at)yahoo.com>
Thanks Bob, I need to look at the crimping tool box to see what I used to do the crimps. As always, appreciated the insight!! Dave
Just for grins, check out these
documents from my website . . .
http://aeroelectric.com/Mfgr_Data/Connectors/Molex_Waldom/qual_crimp.pdf
http://aeroelectric.com/Mfgr_Data/Connectors/Molex_Waldom/TBO%20Quality%20Crimp%20Handbook.pdf
http://aeroelectric.com/Mfgr_Data/Connectors/Molex_Waldom/crimping%20my%20style.pdf
There are discussions on crimp
quality and in particular, pull tests
to see if your tool/terminal/wire
combination is producing the
desired wire grip.
blues750
PostPosted: Sat Jan 05, 2019 11:22 am    Post subject: Re: Open Barrel Crimp Tools Reply with quote
Bob, here is a pic of the crimp tool I used. As I dug the tool out to take a picture, It dawned on me that I had used this on 14ga wires. The tool is not suitable for that size wire. So, it seems reasonable/likely that the crimps were not formed correctly. Bad crimp, high resistance, crispy wire...?
Dave
 Filesize:  468.51 KB
 Viewed:  4946 Time(s)
