Relay sticking
cluros(at)gmail.com
PostPosted: Mon Dec 24, 2018 5:15 pm    Post subject: Relay sticking Reply with quote
We had a strange event last week with our O-200 powered CH750. After running the battery down during a fuel gauge calibration that lasted over an hour, one of our pilots tried to start the engine to taxi back but with the already depleted battery and a less than perfect start procedure they gave up after a couple weak start attempts. I walked over to the aircraft to brief them on a prop start and when I asked for the master on the starter ran. Shut the master off, cycled the start button rapidly a dozen times, master on again and the starter ran again. I could hear the starter relay clicking loudly each time power was applied so it does not seem like there was a physical failure of the relay but more some electrical short activating the relay each time power was applied.
The build team inspected the relay and found a loose connection. Tightening it took the problem from continuous to intermittent; in their words "it's fixed but it did it again once".
We have removed the relay for replacement, I still think the switch is suspect but they've decided the problem is the relay. Does the aeroelectric list think there would be value in cutting open the relay and examining it? Any suggestions on how best to do so?
Thank you,
Sebastien
Kellym
PostPosted: Mon Dec 24, 2018 6:12 pm    Post subject: Relay sticking Reply with quote
I don't think you have a problem. I think that if the engine didn't
actually start, the starter might not reach enough speed to disengage.
Also, extended cranking at low voltage probably heated the solenoid a
lot, causing sticking in it. After the battery is fully recharged, give
it another try, without cranking more than 10-15 seconds on any try. It
is likely to start, and the starter will disengage normally. You can
test the relay on the bench, without a starter connected, just battery
cable on input side and switchable 12V on ignition terminal, just
activating long enough to see your multi-meter show voltage on the
output terminal.
Thank you,
Sebastien
Kelly McMullen
KCHD
alec(at)alecmyers.com
PostPosted: Mon Dec 24, 2018 8:46 pm    Post subject: Relay sticking Reply with quote
I say change the relay. (And have done, on two different aircraft, for identical symptoms.) If the relay sticks on a good engine start it will take the starter motor with it, unless you shut it down soon, and it’s hard to spot unless you have a “starter energized” lamp. In my case I was lucky, the massive current drain took the radio out before I took off, but I only worked out why when I heard the weird grinding noise of the engine driving the locked up starter when I took my headset off.
That was an O235 engine, similar starter configuration to yours.
Do you have a “starter energized” lamp?
On Dec 24, 2018, at 21:04, Kelly McMullen <kellym(at)aviating.com> wrote:
I don't think you have a problem. I think that if the engine didn't actually start, the starter might not reach enough speed to disengage.
Also, extended cranking at low voltage probably heated the solenoid a lot, causing sticking in it. After the battery is fully recharged, give it another try, without cranking more than 10-15 seconds on any try. It is likely to start, and the starter will disengage normally. You can test the relay on the bench, without a starter connected, just battery cable on input side and switchable 12V on ignition terminal, just activating long enough to see your multi-meter show voltage on the output terminal.
Thank you,
Sebastien
cluros(at)gmail.com
PostPosted: Mon Dec 24, 2018 9:09 pm    Post subject: Relay sticking Reply with quote
We do not have a starter energized light but we do have a Dynon Skyview so I'm thinking there must be a way of connecting it to a GP input to display a warning. Have not checked the Dynon install manual yet.
On Mon, Dec 24, 2018, 20:50 Alec Myers <alec(at)alecmyers.com (alec(at)alecmyers.com) wrote:
--> AeroElectric-List message posted by: Alec Myers <alec(at)alecmyers.com (alec(at)alecmyers.com)>
On Dec 24, 2018, at 21:04, Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)> wrote:
--> AeroElectric-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
> Thank you,
> Sebastien
br> fts!)
r> > e.com" rel="noreferrer noreferrer noreferrer" target="_blank">www.mypilotstore.com
rel="noreferrer noreferrer noreferrer" target="_blank">http://www.matronics.com/contribution
Electric-List" rel="noreferrer noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
eferrer noreferrer noreferrer" target="_blank">http://forums.matronics.com
WIKI -
errer noreferrer noreferrer" target="_blank">http://wiki.matronics.com
Kellym
PostPosted: Tue Dec 25, 2018 7:46 am    Post subject: Relay sticking Reply with quote
Be very careful with your generalizations. A Continental starter is very
different than a Lycoming starter. There are no models I know of shared
between those brands. So it is pretty unlikely that they are "similar
configuration". Lycoming starters are on the front of the engine,
Continentals on the rear of the engine, just for example. Some may have
a relay (solenoid) mounted on the starter, some do not. You may be right
about replacing relay, given the generally low cost.
Yes, having a starter energized lamp is a good suggestion regardless.
Kelly McMullen
KCHD
PostPosted: Tue Dec 25, 2018 9:36 am    Post subject: Relay sticking Reply with quote
On Dec 25, 2018, at 10:45 AM, Kelly McMullen <kellym(at)aviating.com> wrote:
Be very careful with your generalizations. A Continental starter is very different than a Lycoming starter. There are no models I know of shared between those brands. So it is pretty unlikely that they are "similar configuration”.
For sure. I understood Sebastien had a Lycoming O-200, and the aircraft I was writing about has a lycoming O-235. If he has a Continental O-200 then they’re not similar.
However the second engine wth which I had a sticky starter solenoid problem was a Continental IO-470, where the starter adapter is damaged within a few seconds of a locked up starter contactor, The starter adapter is impossible to reach without removing the engine from the aircraft. Lycoming - or Continental - I would take absolutely no chances with running either engine with the slightest suspicion of a sticky solenoid.
PostPosted: Tue Dec 25, 2018 9:38 am    Post subject: Relay sticking Reply with quote
Sorry - I should be less ambiguous. We’re talking about sticky starter *contactors* - regardless of whether the starter has a solenoid or some other engagement mechanism. A new contactor is about $100 for a PMA one. Princess Auto (I know Sebastien is in Canada) used to do an intermittent duty 12v contactor of identical dimensions for CDN$16.
cluros(at)gmail.com
PostPosted: Tue Dec 25, 2018 9:58 am    Post subject: Relay sticking Reply with quote
Sorry, I didn't know Lycoming made an O-200, this one is a Continental. In any case we think the problem is in the relay or switch, not the starter itself.
We are planning on replacing the relay with one of these:
https://aircraftspruce.ca/catalog/elpages/starterrelay.php
At $20 it seems a good idea.
What I'm wondering about is how to best cut open the old one in order to see how the failure may have occurred?
On Tue, Dec 25, 2018, 09:43 Alec Myers <alec(at)alecmyers.com (alec(at)alecmyers.com) wrote:
On Dec 25, 2018, at 11:55 AM, Alec Myers <alec(at)alecmyers.com (alec(at)alecmyers.com)> wrote:
On Dec 25, 2018, at 10:45 AM, Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)> wrote:
br> fts!)
WIKI -
PostPosted: Tue Dec 25, 2018 10:07 am    Post subject: Relay sticking Reply with quote
After checking, I guess they don’t! Sorry for the confusion.
BARRY CHECK 6
PostPosted: Tue Dec 25, 2018 7:21 pm    Post subject: Relay sticking Reply with quote
Sabastien:
There are three test you should do:
1 - Test the Relay
2 - Test the Start Switch
3 - Test the wiring for the Start Switch
Test the Relay - Test 1:
a> Remove the wires connected to the relay.
b> Using an Ohm Meter read across the Contacts
Without power applied to the relay you should read an open.
c> Using an Ohm Meter read across the Coil
You should read some value of resistance.
The issue is:  IS there one contact or two?
If one, then the case is your other contact.
AND one contact COULD BE off the INPUT side which would be your B+
d> Using an Ohm Meter read across ONE Coil to Ground (CASE) and then
e> Using an Ohm Meter read across ONE (the other ) Coil to Ground (CASE)
Start Switch Test 2:
a> Remove the wires to the Start Switch.
With the switch NOT pressed it should read open
c> Press the Switch.
With the switch pressed it should read closed (zero ohms).
If anything other than above replace the switch.
Test the wiring for the Start Switch Test 3:
a> Since you have the wires already disconnected from the Switch and the Relay you can do two checks
a1> Across the wires that came off the Start Switch.
They should read open.
a2> From ONE end of a wire from the switch to the other end of the wire where it connects to the Start Relay.
You should read a close (zero ohms) for each wire.
IF you get anything other than the above - Replace the wires.
OK - Are you ready to POWER TEST the Starter Relay?
IF SO - DISCONNECT IT FROM THE STARTER MOTOR.
Well, it already should have been done if you followed instructions in Test 1.
Using a set of jumper leads.
Run a lead from the Battery + to the INPUT side of the Start Relay.
Run a second lead from the Battery - (Ground) to the Coil terminal of the relay.
It should snap CLOSED.
Well, it may not IF you have a relay that has two (2) Coil Terminals.  Some relays use an independent + & - connections.
IF you have a single coil terminal your INPUT Battery B+ will be readable on the OUTPUT relay terminal.  Now, here is a TRICK -
Step 1:  Read the Voltage across the CLOSED relay terminals.  It should read ZERO!
If you have a voltage that means there is a RESISTANCE internally in the relay contacts.
Throw the relay away!
Step 2: While CLOSED,  take a resistance reading Across the Input & Output.
You should read ZERO Ohms.  Why do I call this a TRICK?  Because you are reading a Resistance while there is a voltage on the same terminals.  YEAH!  It is possible to read resistance.  And, if you do...  Throw the relay away.  You want ZERO resistance.
Last test:  Does the relay have Diode across the Coil?
1 - It should be installed with the + side of the Diode on the Negative - side of the Coil.
2 - Check  the Diode for Forward to Reverse Bias Resistance.  There should be a Minimum of 10:1 Reverse to Forward.
OR...  Just throw it away and replace it with a New Diode.
OR...  Of course you could just replace the relay and diode without testing it.  That way you know the circuit has a good relay - But,  you have no proof that the old relay is bad.  What about the wires and the Start Switch?
Side Note:  I always, well, almost always,  use the above procedure ONLY because sometimes the R&R of the relay is way more time consuming and/or requires two people.  AND, I hate being a Pull & Replace Mechanic.  You would never know if it was the relay or just a bad ground.
Barry
On Mon, Dec 24, 2018 at 8:19 PM Sebastien <cluros(at)gmail.com (cluros(at)gmail.com)> wrote:
Thank you,
Sebastien
PostPosted: Thu Dec 27, 2018 9:11 am    Post subject: Relay sticking Reply with quote
The vast majority of starter contactor
sticking events occur during an attempt
to crank the engine with a weak battery.
The fact that you got immediate starter
action on closure of the master switch
says your starter contactor was 'stuck'
shut.
Contacts are welded . . .
Go to a car parts store and pick
up a starter contactor that looks
like the one in the aircraft spruce
catalog . . . it will work just fine.
See if the contactor is marked "diode
suppressed" or has the word diode on it
anywhere or on the packaging.
[img]cid:.0[/img]
 Filesize:  156.73 KB
 Viewed:  17826 Time(s)
PostPosted: Thu Dec 27, 2018 9:12 am    Post subject: Relay sticking Reply with quote
At $20Â it seems a good idea.
Any similar contactor from your local car-parts
emporium will do nicely . . .
Send it to me and I'll conduct an
'up town' failure analysis and report
back.
BARRY CHECK 6
PostPosted: Thu Dec 27, 2018 6:04 pm    Post subject: Relay sticking Reply with quote
Bob,
Cutting open of a relay depends on the design of the relay.  If you are talking the standard hermetically sealed / rolled over edge type, you do NOT cut it open...  You simply grind off the rolled over edge.  This can be done very carefully so none of the metal filings enter the relay.  If done carefully you may even find water inside the relay.  That is what I found in mine!
Next trick:  If you replace the relay with the same kind (hermetically sealed) do the following:
Get a pint of epoxy paint.
Mask the terminals of the relay.
Using a heat gun heat the relay hot enough that you can not touch it.
Then totally submerge the relay in the epoxy paint.
As the relay cools it will suck in the epoxy paint into the rolled edge and seal out any paint.
NOW!  You have a hermetically sealed relay.
Not done yet...  Next trick:  Make sure you mount the relay so the edge of the rolled edge is facing DOWN.  Now water and ice will not collect.
Barry
On Thursday, December 27, 2018, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
  back.
Barry
"Chop'd Liver"
If you wash your hands before you go to the bathroom you may have the makings of a Crew Chief.
PostPosted: Thu Dec 27, 2018 7:02 pm    Post subject: Relay sticking Reply with quote
At 08:02 PM 12/27/2018, you wrote:
Bob,
hermetically sealed implies
absolute atmospheric isolation
between interior and the
environment. Contactors with
rolled on caps are not 'hermetic',
only very secure.
/ rolled over edge type, you do NOT cut it open... You simply grind off the rolled over edge. This can be done very carefully so none of the metal filings enter the relay. If done carefully you may even find water inside the relay. That is what I found in mine! Â
Yep . . . been there a few dozen times.
https://tinyurl.com/p2x7fbl
https://tinyurl.com/kcc26jt
Cessna attempted some DIY sealing techniques
on the whisky barrel relays . . . right
after the noise reducing, floating cowl
was incorporated onto the SE aircraft.
Virtually no help. You could not guarantee
quality of seal. Liquid water sucked in
during a cooling event had to exit as a vapor
over successive atmospheric 'breathing'
cycles . . . i.e. once inside it stayed
inside.
or cap facing down with a #40 drain
hole added right in the center. Now
trapped liquid had a place to get
out.
PostPosted: Wed Jan 02, 2019 6:17 am    Post subject: Relay sticking Reply with quote
out.
Barry - You must be associated with the Three Stooges... Remember when they were sitting in a row boat and it sprung
a leak... If you have a hole at one end of the boat leaking water in, all you have to do is drill another hole at
the other end to let the water out! Isn't that correct? That is EXACTLY what you are suggesting. Also, you did
not address the issue of having the rolled edge facing Up where water and ice can accumulate.
Bob, if you continue to attack me with your warped logic I will be forced to sink your rubber ducky. As much of
your logic has already has discrepancy holes. BUT! If I am incorrect on something and after you thoughtfully
review my point AND if you have a true improvement to my suggestion please post it. Other wise you look like
you are criticizing just to attack.
Barry
Barry, I have not 'attacked' you, nor have I
suggested any short-falls in your intelligence
or integrity laced with derisive or pejorative
prose.
I have attempted to offer explanations
of cause/effect/remedy for a constellation
of failures. Analysis of those failures
was a prime-directive in my 45+ years at
Cessna (3x), Beech (2x), Lear, Boeing
and Electro-Mech (3x) where my work not
only had to produce beneficial outcomes
but was subject to review by my peers.
Recall that this thread began
with discussions about welding
in a starter contactor (high pressure, small
area contacts) due to weak battery
condition . . . but morphed into
some discussion about failures in
battery contactors (low pressure,
large area contacts) with an entirely
different failure mode.
You first stated that the rolled closure
on the metal housing of a contactor
was 'hermetic' then you suggest
there is some value in orienting that
joint to ward off effects of accumlated
of 'water and ice'?
Moisture gets into non-hermetic devices
with a combination water vapor/liquid
at the leak site AND a pressure differential
due to effects atmosphere (weak) or temperature
(strong). Battery contactors heat up
significantly while energized. When
de-energized, a substantial pressure
differential occurs as the device
cools. If there is moisture at
the location of any leak, it is
sucked inside.
Drilling the hole in the low spot on
a contactor cap facing down has two
benefits. It provides a drain for
liquid condensate AND a pressure
relief that stops a cooling contactor
from 'sucking' moisture across the
non-hermetic seal at the housing-to-
cap interface.
I'm sorry if you feel 'attacked'.
That's not my mission here. This is all
about the simple-ideas in physics that
drive the utility of our favorite machines.
Ideas that were a foundation for a
successful career and, I believe, worthy
of sharing in the OBAM aviation community.
If I mis-understand something, I'm intently
interested in knowing it . . . as a teacher
I have a duty to NOT propagate bad data.
So I invite you to help sift the sands of simple-
ideas and forego disparaging remarks.
trigo(at)mail.telepac.pt
PostPosted: Wed Jan 02, 2019 9:13 am    Post subject: Relay sticking Reply with quote
Bob
It is more than obvious that you (and everyone else) should not waste our time with this gentleman (Barry) opinions.
Just delete them.
Nothing personal, just by having read some of them.
Have an excellent 2019!
Carlos
No dia 02/01/2019, às 14:16, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> escreveu:
out.
Barry
prose.
of 'water and ice'?
sucked inside.
cap interface.
PostPosted: Wed Jan 02, 2019 10:15 am    Post subject: Relay sticking Reply with quote
At 11:11 AM 1/2/2019, you wrote:
Bob
Just delete them.
Carlos
At last count, there were about 1200 subscribers
to the list . . . obviously, ACTIVE participants
number much less but I think it's important to make
sure that poor or unclear data does not go
unchallenged. Of course, any who wish
to bypass the thread are encouraged to do so.
PostPosted: Wed Jan 02, 2019 11:06 am    Post subject: Re: Relay sticking Reply with quote
Quote from Official AeroElectric-List Usage Guidelines
"Feel free to disagree with other viewpoints, BUT keep your tone
polite and respectful. Don't make snide comments, personally attack
other listers,"
If someone posts something that you disagree with, it is best not to quote
them or mention their name. Just state the facts about the electrical subject.
Follow Bob's example. He has contradicted my postings in the past without
offending me. (Although I do not like to admit being wrong. LOL)
Joe Gores
BARRY CHECK 6
PostPosted: Wed Jan 02, 2019 11:35 am    Post subject: Relay sticking Reply with quote
Exactly Joe!
Check your emails, I did not post my response to the gaggle.  It was sent directly to Bob.  After his snide comments.
So, who is attacking whom?
Barry
On Wednesday, January 2, 2019, user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
other listers,"
Joe Gores
http://forums.matronics.com/viewtopic.php?p=486660#486660
br> fts!)
r> > e.com" target="_blank">www.mypilotstore.com
Electric-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
WIKI -
Barry
"Chop'd Liver"
cluros(at)gmail.com
PostPosted: Fri Jan 04, 2019 2:44 pm    Post subject: Relay sticking Reply with quote
Upon examination of the removed starter relay I see that it is a continuous duty relay. It has now been replaced with an intermittent duty relay of appropriate capacity. Thank you for the help everyone but looks like this one was obvious.
On Thu, Dec 27, 2018 at 9:18 AM Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
 shut.
[img]cid:1681b04e58bd7b6b1d31[/img]
 Filesize:  156.73 KB
 Viewed:  17756 Time(s)
