cluros(at)gmail.com Guest
Posted: Mon Dec 10, 2018 9:40 am Post subject: Ford Voltage Regulator |
Well it's working now but not the way I expected. I rewired everything to match Z-11 (except for the OVM, it's on its way) and started the engine, no juice: Battery volts only. Further investigation revealed that the builder thought the current limiter base was the actual current limiter. Installed the current limiter and everything now works fine.
Which leads me to wonder, while the engine was running and there was no current load on the alternator, what were the regulator and alternator doing? I assume that the regulator seeing a constant 12 V would be driving the alternator to maximum voltage in order to try to raise the bus voltage. How high a voltage can one of these alternators produce at 2000 RPM?
On Sun, Nov 25, 2018 at 8:53 AM Sebastien <cluros(at)gmail.com (cluros(at)gmail.com)> wrote:
| Quote: | So for any VR166 regulator and Ford type alternator combination wire as per Z-11.
Thank you Bob.
On Sun, Nov 25, 2018, 08:46 Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com) wrote:
| Quote: | At 09:18 PM 11/24/2018, you wrote:
| Quote: | | Z-11 shows the S wire of the Ford regulator tied in to the A terminal. Our Hartzell alternator has a dedicated Sta terminal so I'm guessing that the S terminal of the regulator should go to the Sta terminal on the alternator instead of being tied into the alternator switch going to the A terminal? Can anyone please confirm if this makes sense or not? |
The "s" terminal did go to the stator
winding in cars . . . but is best
paralleled with "a" in airplanes.
Ignore the aux, n or s terminals on
the alternator.
http://www.aeroelectric.com/Reference_Docs/Alternator_Data/Legacy_EM_Regulator_(Ford).pdf
This is because the solid state replacement
for the Ford E-M regulator is NOT a
strictly functional replacement. The "S"
terminal does not behave in the same
manner as it did on the E-M products.
Joined: 28 Mar 2008 Posts: 1966 Location: Riley TWP Michigan
Posted: Mon Dec 10, 2018 12:01 pm Post subject: Re: Ford Voltage Regulator |
No personal experience, but from what I have read, an alternator can put out well over 100 volts when lightly loaded and field current at maximum.
_________________ Joe Gores |
Posted: Mon Dec 10, 2018 12:22 pm Post subject: Ford Voltage Regulator |
At 11:39 AM 12/10/2018, you wrote:
| Quote: | Well it's working now but not the way I expected. I rewired everything to match Z-11 (except for the OVM, it's on its way) and started the engine, no juice: Battery volts only. Further investigation revealed that the builder thought the current limiter base was the actual current limiter. Installed the current limiter and everything now works fine.
Which leads me to wonder, while the engine was running and there was no current load on the alternator, what were the regulator and alternator doing? I assume that the regulator seeing a constant 12 V would be driving the alternator to maximum voltage in order to try to raise the bus voltage. How high a voltage can one of these alternators produce at 2000 RPM? |
Without knowing the alternator's minimum rpm
for regulation value, it cannot be predicted
accurately . . . but it IS pretty high. A
runaway alternator on a Lycoming (hi ratio
belt drive) at cruise rpm can be spectacular.
Probably over 200 volts.
Fortunately, the only risk for no-load
operation is to the rectifiers. If everything
seems normal after the critter was properly
wired, then the rectifiers are probably
okay.
