Wing storage
eoinmaguire(at)hotmail.co
PostPosted: Sat Dec 08, 2018 2:41 pm    Post subject: Wing storage Reply with quote
Hi All
Just wondering has anyone any designs for a storage dolly to keep the wings in a vertical position for the winter.
I have the aircraft stored at the moment and due to space constraints I need to keep the wings vertical and preferably easily movable.
Kind Regards
Eoin
freddythek10(at)gmail.com
PostPosted: Sat Dec 08, 2018 5:24 pm    Post subject: Wing storage Reply with quote
Do you mean vertical in the sense that the wingtip is at the top and the spar is pointing at the ground?
On Dec 8, 2018, at 2:39 PM, Eoin Maguire <eoinmaguire(at)hotmail.com> wrote:
Hi All
Kind Regards
Eoin
PostPosted: Sat Dec 08, 2018 9:25 pm    Post subject: Wing storage Reply with quote
Hi Fred
Nope horizontal I suppose would be a better description.....
> Hi All
> Kind Regards
> Eoin
> Sent from my iPhone
davidjoyce(at)doctors.org
PostPosted: Sun Dec 09, 2018 1:42 am    Post subject: Wing storage Reply with quote
Eoin, what has worked well for me over the years is to use a trestle (constructed out of 2x3&rdquo; wood) to support the spars, clamped on to the top of the trestle with a G clamp, whilst the downward pointing leading edges are simply resting on a low (1 ft high) tressle with some durable soft material glued to its top. David Joyce, GXSDJ
On 2018-12-08 22:39, Eoin Maguire wrote:
--> Europa-List message posted by: Eoin Maguire <eoinmaguire(at)hotmail.com (eoinmaguire(at)hotmail.com)>
Hi All
Kind Regards
Eoin
lotstore.com
.matronics.com/contribution
ttp://www.matronics.com/Navigator?Europa-List
ics.com
.com
alan.twigg775(at)gmail.co
PostPosted: Sun Dec 09, 2018 1:50 am    Post subject: Wing storage Reply with quote
Eoin, I have a stand Neville Eyre used and gave to me. I have extended it for long wings.
I will send a picture direct to your email.
Alan Twigg
On 9 Dec 2018, at 05:23, Eoin Maguire <eoinmaguire(at)hotmail.com> wrote:
Hi Fred
> Sent from my iPhone
>> Hi All
>> Kind Regards
>> Eoin
>> Sent from my iPhone
clivesutton
PostPosted: Mon Dec 10, 2018 1:23 am    Post subject: Re: Wing storage Reply with quote
Hello Eion,
If it helps, my solution is shown in the attached pic
Both supports are on 4 castors and on each, one wing cut-out is deeper than the other enabling storage with both spars together or opposed to aid of the available storage space. The two supports can be 'ganged' together with the horizontal strips of wood - to improve the ease of rolling the whole lot around, but i rarely find that extra precaution to be necessary.
The wing-shaped cutouts are deliberately inclined towards each other (upper surfaces face each other) to aid stability when stood outside unattended in a light breeze e.g. whilst you are waiting to put them onto or off of, a trailer.
Clive
 Filesize:  1.15 MB
 Viewed:  10337 Time(s)
PostPosted: Mon Dec 10, 2018 5:52 am    Post subject: Wing storage Reply with quote
Hi Clive
Looks great, I’ve got a few great options so far!
Eoin
On 10 Dec 2018, at 09:26, clivesutton <clive.maf(at)googlemail.com> wrote:
Hello Eion,
Clive
http://forums.matronics.com/viewtopic.php?p=486202#486202
http://forums.matronics.com//files/20140228_200046_154.jpg
sim(at)4lists.simonliebol
PostPosted: Mon Dec 10, 2018 6:22 am    Post subject: Wing storage Reply with quote
Another solution attached. Not as nice but it works. I didn't build the
stands.
Simon
 Filesize:  194.71 KB
 Viewed:  10319 Time(s)
flyingphil2
PostPosted: Tue Dec 11, 2018 3:34 am    Post subject: Re: Wing storage Reply with quote
I recognise those wing stands Simon.
Yes, they are functional but I think Clive's are far more elegant.
Hope your build is going well Smile
PostPosted: Thu Dec 13, 2018 5:27 am    Post subject: Wing storage Reply with quote
Hi Phil,
Smile They are simple and fit their intended purpose.
I may finally have found a workshop within walking distance from home. I
will contact you directly regarding those wings.
Simon
