DC - DC Converter
Rocketman1988
PostPosted: Tue Nov 20, 2018 5:39 pm    Post subject: DC - DC Converter Reply with quote
Anyone have a recommendation on a 12VDC to 5VDC converter that isn't too noisy?
ceengland7(at)gmail.com
PostPosted: Tue Nov 20, 2018 6:02 pm    Post subject: DC - DC Converter Reply with quote
Check with Steinair.
Charlie
On Nov 20, 2018, at 8:44 PM, Rocketman1988 <rocketman(at)etczone.com (rocketman(at)etczone.com)> wrote:
--> AeroElectric-List message posted by: "Rocketman1988" <Rocketman(at)etczone.com>Anyone have a recommendation on a 12VDC to 5VDC converter that is too noisy?Read this topic online here:http://forums.matronics.com/viewtopic.php?p=485375#485375ef="http://www.matronics.com/contribution">http://www.matronics.cavigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElec/www.matronics.com/contribution">http://www.matronics.com/contribution
art(at)zemon.name
PostPosted: Tue Nov 20, 2018 6:09 pm    Post subject: DC - DC Converter Reply with quote
I bought this $25 wonder from Aircraft Spruce.
https://www.aircraftspruce.com/catalog/elpages/eadualusbpanel.php
I have not flow with it yet but I expect that it will be just fine. Big plus for me was that it installs in a round hole.
    -- Art Z.
On Tue, Nov 20, 2018 at 8:02 PM Rocketman1988 <Rocketman(at)etczone.com (Rocketman(at)etczone.com)> wrote:
--> AeroElectric-List message posted by: "Rocketman1988" <Rocketman(at)etczone.com (Rocketman(at)etczone.com)>
https://CheerfulCurmudgeon.com/"Be kind, for everyone you meet is fighting a hard battle."
Rocketman1988
PostPosted: Tue Nov 20, 2018 6:51 pm    Post subject: Re: DC - DC Converter Reply with quote
Thanks. I am really looking for a 5v supply to drive some servos. There are plenty of switching regulators out there but I am curious as to the effect on the radios...
PostPosted: Tue Nov 20, 2018 7:07 pm    Post subject: Re: DC - DC Converter Reply with quote
There is a thread on VansAirforce about 5 volt USB ports.
http://www.vansairforce.com/community/showthread.php?t=87369
Joe Gores
Rocketman1988
PostPosted: Tue Nov 20, 2018 7:28 pm    Post subject: Re: DC - DC Converter Reply with quote
Not looking for a USB port. Looking for a 5v power supply that will power some servos and have minimal EMI for the radios...
gerald.champagne(at)gmail
PostPosted: Tue Nov 20, 2018 7:50 pm    Post subject: DC - DC Converter Reply with quote
You could use something like this that's specifically designed to power servos that are sitting right next to a radio receiver:
http://home.castlecreations.com/becs
http://www.castlecreations.com/en/accessories-5/cc-bec-010-0004-00
They're small, they're cheap, they're RF friendly, and the output voltage is programmable.  I've used them on several RC projects and they work great.
Gerald
On Tue, Nov 20, 2018 at 9:33 PM Rocketman1988 <Rocketman(at)etczone.com (Rocketman(at)etczone.com)> wrote:
http://forums.matronics.com/viewtopic.php?p=485383#485383
br> fts!)
r> > e.com" rel="noreferrer" target="_blank">www.mypilotstore.com
WIKI -
donvansanten(at)gmail.com
PostPosted: Tue Nov 20, 2018 7:59 pm    Post subject: DC - DC Converter Reply with quote
Or try  Max Products Inc's rc regulators.
On Tue, Nov 20, 2018, 19:54 Gerald Champagne <gerald.champagne(at)gmail.com (gerald.champagne(at)gmail.com) wrote:
Gerald
br> fts!)
WIKI -
glastar(at)gmx.net
PostPosted: Tue Nov 20, 2018 9:44 pm    Post subject: DC - DC Converter Reply with quote
If you  want to run your ow, I have very good experience with Traco
Power DC-DC converters, they come
 in all kind of varieties, also high power once, they are clean and
work perfect since over 15 years in my plane
 Mouser does sell them
Cheers Werner
PostPosted: Wed Nov 21, 2018 7:43 am    Post subject: DC - DC Converter Reply with quote
Unless it's an off-the-shelf device
specific to aviation, there is little
to be known about their emissions
and even then, they may not have been
tested in the lab, only operated in
one or more airplanes and found to be
compatible.
Pick any down-converter that meets your
performance needs. Adding filtering
is generally not a gut-wrenching experience
should your particular selection prove
'incompatible'.
