r.twellmann(at)steute.com Guest
Posted: Tue Nov 13, 2018 11:59 pm Post subject: AW: Re: Can anyone help me with a wing template? |
Hello,
here is a DXF file of the airfoil with the appropriate cord length of 1167 mm. (yes, we use the metric system )
I also added the 3 degree line you need to set the wing to the right angle.
You should find somebody who has access to a big format printer to print it out for you.
Good luck with the construction of your plane and don`t hesitate to ask if you have further questions.
Best regards from Germany,
Ralf Twellmann (KIS# 104)
Tel.: +49 / (0)5731 745-158
Fax: +49 / (0)5731 745-222
mailto:r.twellmann(at)steute.com
http://www.steute.com
-----Ursprüngliche Nachricht-----
Von: owner-kis-list-server(at)matronics.com [mailto:owner-kis-list-server(at)matronics.com] Im Auftrag von threetracker
Gesendet: Mittwoch, 14. November 2018 05:26
An: kis-list(at)matronics.com
Betreff: Re: Can anyone help me with a wing template?
Tim has suggested that since the TR-1 wing is a straight wing someone could remove a wingtip and trace the planform for me. I do have the molded wing tips and I'm going to see how the traced shape looks for constructing a template.
Thank you Tm. It might just work and it's at least worth a try. I can carefully see how accurate a shape I can get off of two wing tips where they attach to the end of the wings. That is still more accurate than a guess at the shape based on ribs and skins.
http://forums.matronics.com/viewtopic.php?p=484997#484997
| | - The Matronics KIS-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
NACA_63-215_with_3_Degrees.DXF |
68.64 KB |
634 Time(s) |
Robert Reed
Joined: 22 Oct 2009 Posts: 331 Location: Dallas/Ft.Worth
Posted: Wed Nov 14, 2018 5:31 am Post subject: AW: Re: Can anyone help me with a wing template? |
Thank you Ralf, it’s great that after all this time the KIS builders are still supporting each other.
Thank you
Bob Reed
| Quote: | On Nov 14, 2018, at 1:58 AM, Twellmann, Ralf <r.twellmann(at)steute.com> wrote:
Hello,
<NACA 63-215 with 3 Degrees.DXF>
Posted: Wed Nov 14, 2018 9:48 am Post subject: AW: Re: Can anyone help me with a wing template? |
My pleasure, Bob.
I forgot to mention that different from the drawing i sent, the airfoil on the KIS has no crusp at the trailing edge (the shape is not curved inwards) but straight. So simply replace the curve in the aileron/ flap area with a straight line. This was done to simplify construction.
Regards, Ralf
| Quote: | Am 14.11.2018 um 14:33 schrieb Robert Reed <robertr237(at)att.net>:
Thank you
Bob Reed
> Hello,
