n7188u
Posted: Wed Nov 28, 2018 12:38 pm Post subject: Aileron closeout reinforcement question |
Chris,
For what its worth i reinforced the whole closeout including joint between the aileron balance boxes and the lower surface of the wing. I used flox on all the sharp corners. Dont go over the upper side of the aileron balance boxes otherwise you'll have difficulty with putting the top skin on
will
William Daniell
XS 912 turbo airmaster Dynon Skyview with 100 Flight
+57 310 295 0744
On Wed, Nov 28, 2018 at 1:28 PM n7188u <chmgarb(at)gmail.com (chmgarb(at)gmail.com)> wrote:
| Quote: | --> Europa-List message posted by: "n7188u" <chmgarb(at)gmail.com (chmgarb(at)gmail.com)>
Dear Europa forum members,
I am getting ready to reinforce the aileron closeouts on the wings (chapter . Figure 8 of this chapters says to apply the reinforcement full length but not to flox the aileron balance areas. The question is: is the BID reinforcement applied also over the balance areas or not? The indication not to use flox would point to not reinforcing the balance areas and the reference to full length is just indicating the reinforcement is along the entire closeout (but not on the balance areas).
is my understanding correct?
Chris
http://forums.matronics.com/viewtopic.php?p=485845#485845
br> fts!)
r> > e.com" rel="noreferrer" target="_blank">www.mypilotstore.com
-Matt Dralle, List Admin.
FORUMS -
WIKI -
b Site -
n7188u
Posted: Wed Nov 28, 2018 1:17 pm Post subject: Re: Aileron closeout reinforcement question |
Thanks for the info Will. I guess the only disadvantage of placing the reinforcement over the thin skin where the balance boxes go is them getting pushed up and interfering with the upper skin (as you mentioned). Let's see what other people say.
