mike(at)vision499.com Guest
Posted: Fri Nov 02, 2018 9:01 am Post subject: LOM STARTED |
Thank you very much to everybody that assisted.
The engine finally started and is running very smoothly.
I borrowed a manual primer pump from a friend and that solved the priming issue, it started but would not run continuously and a friend suggested that the injectors may need bleeding.
After bleeding the injectors all was well
I bought a SLICKSTART on e-bay a while back but it is defective and went with the vibrator instead of getting a new Slickstart
How much of an improvement is there with a Slickstart?
Thanks again for the help
Mike
From: owner-lom-list-server(at)matronics.com <owner-lom-list-server(at)matronics.com> On Behalf Of sjbeaver
Sent: October 25, 2018 4:39 AM
To: lom-list(at)matronics.com
Subject: Re: LOM Primer issue
The primer nozzle is just another fuel injector nozzle and so requires a pressure of somewhere in the 80 psi+ range. That is easily achievable with a common plunger type primer, but there is no way it is going to open with a Facet pump. LOMs are hard to start without prime, but start readily with a couple of squirts.
Since you are concerned about starting, how is you starter vibrator? (Or have you installed a Slickstart?) If you are using the vibrator, take the lid off and ensure that it is vibrating vigorously when the starter is engaged. They are finicky little buggers and require cleaning and adjusting from time to time, which is why so many people replace them with a Slickstart.
Feel free to telephone if I can be of assistance.
Steve
Stephen Beaver
Tel: 614-937-4189
On Oct 25, 2018, at 12:04 AM, <mike(at)vision499.com (mike(at)vision499.com)> <mike(at)vision499.com (mike(at)vision499.com)> wrote:
Thank you very much for the help with the starter, I checked on youtube and I think my starter is normal, I just expected it to turn much faster
Main culprit that has now been identified is an inoperative primer
I am using a facet fuel pump from Aircraft spruce
https://www.aircraftspruce.ca/catalog/eppages/facetpumps.php
Combined with an electric solenoid engine primer valve
https://www.aircraftspruce.ca/catalog/appages/elsolprimer.php?clickkey=28343
This combination does not seem to generate enough pressure to open the valve in the primer nozzle in the intake manifold, suggestions on what to use for a primer pump would be appreciated. Any ideas on where I can find out at what pressure the nozzle opens?
Mike
From: owner-lom-list-server(at)matronics.com (owner-lom-list-server(at)matronics.com) <owner-lom-list-server(at)matronics.com (owner-lom-list-server(at)matronics.com)> On Behalf Of sjbeaver
Sent: October 22, 2018 4:29 AM
To: lom-list(at)matronics.com (lom-list(at)matronics.com)
Subject: Re: LOM STARTER
The 12v version of the starter is quite rare, so I must first ask are you absolutely 100% sure that you have a 12v starter? If you are, then put a volt meter across the starter terminal and measure the voltage when you attempt to start the engine.
How close is the reading to 12v?
With the supercharger disengaged, does the starter spin quickly and easily when you press the starter button?
Does the engine turn freely by hand?
Since the starter drives the engine through the supercharger gearing, it takes rather less power than most starters. I use only very small 9 AH lead acid battery and my engine cranks vigorously. It is 24v, however.
Steve
Stephen Beaver
Tel: [url=tel:614-937-4189]614-937-4189[/url]
On Oct 22, 2018, at 12:16 AM, <mike(at)vision499.com (mike(at)vision499.com)> <mike(at)vision499.com (mike(at)vision499.com)> wrote:
Hello All
Tried to start my 4 cylinder LOM with supercharger and 12 volt starter for first time to-day.
Starter seems very sluggish and does not want to spin the engine and seems to struggle to get past one compression stroke.
Wiring does not get warm but starter gets warm very quickly
Any advise or observations?
Mike
Mike Pienaar
mike(at)vision499.com (ike(at)vision499.com)
Home: [url=tel:+1%20250-999-8121]+1 250-999-8121[/url]
Mike cell: [url=tel:+1%20250-885-0554]+1 250-885-0554[/url]
1-1100 Tulip Ave, Victoria, BC, V8Z 0A2
Virus-free. www.avast.com
| | - The Matronics Lom-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lom-List |
sjbeaver(at)gmail.com Guest
Posted: Fri Nov 02, 2018 9:13 am Post subject: LOM STARTED |
Wentworth aircraft sell Slickstarts for about $200. I have bought several from there for LOM users overseas.
There are two main advantages:
1. Less maintenance since there are no points to clean and adjust
2. Much more reliable starting if the battery is weak. (The Slickstart operates down to about 8 volts, so if the prop moves even one compression, the engine will likely start) Steve-- Stephen BeaverTel: 614-937-4189
| Quote: | On Nov 2, 2018, at 1:01 PM, <mike(at)vision499.com (mike(at)vision499.com)> <mike(at)vision499.com (mike(at)vision499.com)> wrote:
Mike
From: owner-lom-list-server(at)matronics.com (owner-lom-list-server(at)matronics.com) <owner-lom-list-server(at)matronics.com (owner-lom-list-server(at)matronics.com)> On Behalf Of sjbeaverSent: October 25, 2018 4:39 AMTo: lom-list(at)matronics.com (lom-list(at)matronics.com)Subject: Re: LOM Primer issue
Steve-- Stephen BeaverTel: [url=tel:614-937-4189]614-937-4189[/url]
| Quote: | On Oct 25, 2018, at 12:04 AM, <mike(at)vision499.com (mike(at)vision499.com)> <mike(at)vision499.com (mike(at)vision499.com)> wrote:
Mike
From: owner-lom-list-server(at)matronics.com (owner-lom-list-server(at)matronics.com) <owner-lom-list-server(at)matronics.com (owner-lom-list-server(at)matronics.com)> On Behalf Of sjbeaverSent: October 22, 2018 4:29 AMTo: lom-list(at)matronics.com (lom-list(at)matronics.com)Subject: Re: LOM STARTER
| Quote: | On Oct 22, 2018, at 12:16 AM, <mike(at)vision499.com (mike(at)vision499.com)> <mike(at)vision499.com (mike(at)vision499.com)> wrote:
Hello All
Mike
Mike Pienaar
Posted: Mon Nov 05, 2018 4:03 pm Post subject: LOM STARTED |
Hello Stephen,
Thanks for the input, may I ask you a favour, if you spot a Slickstart at a good price again will you let me know. I don’t normally watch out for goodies but will keep my eyes open as well from now on
Mike
Sent: November 2, 2018 10:06 AM
Subject: Re: LOM STARTED
Steve
Stephen Beaver
Tel: 614-937-4189
Mike
Steve
Stephen Beaver
Mike
Steve
Stephen Beaver
Hello All
Mike
Mike Pienaar
Posted: Mon Nov 05, 2018 5:09 pm Post subject: LOM STARTED |
I think you will find Wentworth Aircraft, and Texas Air Salvage have used ones in stock. I paid $200 for the last couple I bought. Ask for a model SS1001 or SS1002. They are essentially the same and differ only in paperwork
http://www.wentworthaircraft.com
https://www.texasairsalvage.com Steve-- Stephen BeaverTel: 614-937-4189
| Quote: | On Nov 5, 2018, at 7:02 PM, <mike(at)vision499.com (mike(at)vision499.com)> <mike(at)vision499.com (mike(at)vision499.com)> wrote:
Hello Stephen,
Mike
From: owner-lom-list-server(at)matronics.com (owner-lom-list-server(at)matronics.com) <owner-lom-list-server(at)matronics.com (owner-lom-list-server(at)matronics.com)> On Behalf Of sjbeaverSent: November 2, 2018 10:06 AMTo: lom-list(at)matronics.com (lom-list(at)matronics.com)Subject: Re: LOM STARTED
Mike
Mike
Hello All
Mike
Mike Pienaar
