ceengland7(at)gmail.com Guest
Posted: Fri Oct 19, 2018 2:52 pm Post subject: urethane fuel (??) line |
Well, after a year of distractions, I got back on the Kolb this afternoon, hoping to get it flying for our annual Pumpkin Drop here at Slobovia Outernational (MS71). It's been sitting for about 11 months, with the fuel I put in it last year. Non-ethanol premium mogas is what I put in it. I decided to drain the tank to add fresh fuel, so I added some line to the fuel output line (to reach a gas can) and blew into it to pressurize the tank & start fuel flowing. Got great pressure with one lung of air, but only air came back out the line. Finally pulled the fitting (installed in the top of the tank) and it came out with about an inch of the urethane flex line I used to reach the bottom of the tank, with a pickup filter on the other end. You can see in the pic what the pickup line looks like. Strange thing is, the lines on the outside of the tank are in good shape, even though they came off the same roll of fuel line and still have fuel in them.
I guess I'll replace with some teflon lined a/c grade stainless flex line. I must say, I'm a bit surprised that it would rot this badly, this quickly. I thought annual replacement was a precaution; not a "I hope I get this before I die" kind of thing.
BTW, if you're within striking distance of Jackson MS, come on down for the Pumpkin Drop. Contact info on the flier attached.
182.19 KB |
10903 Time(s) |
Pfatchantz(at)protonmail. Guest
Posted: Fri Oct 19, 2018 3:05 pm Post subject: urethane fuel (??) line |
test
Sent with ProtonMail Secure Email.
������� Original Message �������
On Friday, October 19, 2018 5:41 PM, Charlie England <ceengland7(at)gmail.com> wrote:
| Quote: | Well, after a year of distractions, I got back on the Kolb this afternoon, hoping to get it flying for our annual Pumpkin Drop here at Slobovia Outernational (MS71). It's been sitting for about 11 months, with the fuel I put in it last year. Non-ethanol premium mogas is what I put in it. I decided to drain the tank to add fresh fuel, so I added some line to the fuel output line (to reach a gas can) and blew into it to pressurize the tank & start fuel flowing. Got great pressure with one lung of air, but only air came back out the line. Finally pulled the fitting (installed in the top of the tank) and it came out with about an inch of the urethane flex line I used to reach the bottom of the tank, with a pickup filter on the other end. You can see in the pic what the pickup line looks like. Strange thing is, the lines on the outside of the tank are in good shape, even though they came off the same roll of fuel line and still have fuel in them.
Posted: Fri Oct 19, 2018 4:19 pm Post subject: urethane fuel (??) line |
I don't know why folks insist on using plastic fuel line. It's an ultralight thing I guess. Stuff is dangerous. Some that use urethane fuel line say they need it so they can see the fuel?????
Way back in prehistoric days of my ultralighting, I automatically used urethane because that's what came in the kits and everyone else was using it.
After some problems I changed over to neoprene rubber fuel line many years ago. Never had a problem with it. Last for a very long time.  It has been around for a very long time.   But I can't see my fuel......
From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Charlie England
Sent: Friday, October 19, 2018 5:42 PM
Subject: urethane fuel (??) line
_________________ John Hauck
Titus, Alabama |
gdhelton(at)gmail.com Guest
Posted: Fri Oct 19, 2018 4:33 pm Post subject: urethane fuel (??) line |
Hello John. Do you use the reinforced neoprene or just the straight neoprene like Aircraft Spruce sells? Thanks, George George H.
Firestar
Mesick, Michigan
gdhelton(at)gmail.com (gdhelton(at)gmail.com)
On Oct 19, 2018, at 8:19 PM, John Hauck <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)> wrote:
| Quote: | <![endif]--> <![endif]-->
From: owner-kolb-list-server(at)matronics.com (owner-kolb-list-server(at)matronics.com) [mailto:owner-kolb-list-server(at)matronics.com (owner-kolb-list-server(at)matronics.com)] On Behalf Of Charlie England
Posted: Fri Oct 19, 2018 4:48 pm Post subject: urethane fuel (??) line |
I buy the fuel line local, a good grade with pretty stiff wall.
I like Gates. Go to their site. They have a lot of new stuff. Was just looking at submersible fuel line for using inside the fuel tank. Most neoprene rubber fuel line is fuel resistant on the inside, but not on the outside. Submersible is resistant inside and out.
From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of George Helton
Sent: Friday, October 19, 2018 7:34 PM
Subject: Re: urethane fuel (??) line
George H.
Firestar
Mesick, Michigan
Titus, Alabama |
Posted: Fri Oct 19, 2018 5:23 pm Post subject: urethane fuel (??) line |
| Well, shucks. The fuel line image didn't make it through. Let's try again.
Has anyone used any type of 'plastic' fuel line other than the blue urethane stuff? What about other materials? Vinyl? Tygon?
Charlie
260.98 KB |
10901 Time(s) |
Posted: Fri Oct 19, 2018 7:18 pm Post subject: urethane fuel (??) line |
Meetooo....
I buy gates when I can find it locally..otherwise just std auto fuel line.. Very shocking to grab the yellow stuff and have it disintegrate in ones hand..!
pfatchantz...better know as Herb is back on the list..I think..
A note to say that I enjoyed my over nite in Troy Alabama...and my trip to Slocum and Freedom Field to purchase the much passed around James A. Tripp Kolb Firestar II...5th owner... 450 or so hours on airframe and engine...still looks good save a bit of hangar rash.. went down on the 8th , loaded and caught a motel in Troy.Something about a Hurricane??
Came back via 231...for my experience on I-65 told me that "ole Red" , my 1991 F250 Diesel was not happy on the interstate with everyone going 80 to 90 mph.. some beautiful country and quaint towns to be seen heading toward Huntsville...one I recall...weebumka...something like that? I stopped at the McDonalds there and noticed a historical marker at a table in the corner...said John Hauck was the champion coffee drinker in the restaurant... 750 gallons...as I recall.. Don't remember what year??
James built a really good example of a Kolb Firestar...I have seen his color scheme somewhere?? Amazingly , the landing gear is straight and the wheels are at a proper angle...4 previous owners?? I am on the spot now!!
The first thing I noticed after getting it off of the trailer is how difficult it is to handle with the wings folded and how close the wing leading edge was to the ground. The MkIII and Fireflys were easier..
I welded up a three wheel dolly but got the castering front wheel at an angle... it worked well enough to get it into one side of the garage.. Anyone have a picture of a better one... Gotta do a bit more work...Castering wheels like to be level to the ground..maybe perpendicular is better said?
Anyhow..always enjoy reading the list and hearing of the exploits and linking to the vids..
Hope to have the low time 503 installed in time for next spring...Logs do not show a decarb and they look complete...
Carry on....Herb (on the ridge at Breezy Hill Farm)
On Friday, October 19, 2018 7:48 PM, John Hauck <jhauck(at)elmore.rr.com> wrote:
Subject: Re: Kolb-List: urethane fuel (??) line
George H.
Firestar
Mesick, Michigan
Subject: Kolb-List: urethane fuel (??) line
mojaveclimber
Posted: Fri Oct 19, 2018 11:03 pm Post subject: urethane fuel (??) line |
Charlie
I have reverted to quality automotive hose, Gates. The plastic hoses have failed prematurely on my Kolb just  unreliable.
Jim
Kolb Mk 3
Piper PA 28 Cherokee 140
On Fri, Oct 19, 2018 at 6:25 PM Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
Charlie
Virus-free. www.avast.com [url=#m_6492035210160783892_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2] [/url]
Posted: Sat Oct 20, 2018 4:46 am Post subject: urethane fuel (??) line |
Thanks to all for the replies. I sent the 2nd post before noticing that John and others had recommended automotive hose. I'll order some submersible hose & hopefully, be done with this issue.
Charlie
On Sat, Oct 20, 2018 at 2:04 AM Jim Thomson <mojaveclimber(at)gmail.com (mojaveclimber(at)gmail.com)> wrote:
| Quote: | Charlie
Jim
Kolb Mk 3
Charlie
Virus-free. www.avast.com [url=#m_7624744521292491001_m_6492035210160783892_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2] [/url]
Posted: Sat Oct 20, 2018 5:26 am Post subject: urethane fuel (??) line |
You almost got that right, Wetumpka, the big city 15 miles south of hauck's holler. Must have been a mistake on that historical marker's location. It should be placed up here in the country where I do some serious coffee drinking.
James Tripp's Firestar was well built, not that I gave him a hand every once in a while. He is a good craftsman. That FS made several flights to the Kolb Homecoming in London, KY, and one flight to Nauga Field in Star Hill, LA, home of John Bickham, at the time. John B relocated to a flyin community in Los Lunas, NM. What a change from the swamps of LA to the desert of NM. He is now building a Bearcat. In that same community is our buddy Mike Marker who build a FS in addition to 12 or 13 other aircraft. He just finished up a Carbon Cub a couple years ago. I think he's building an RV8 now. They are part of our Kolb group that show up at the Rock House each year for our annual flyin.
Herb, I reckon you'll get this FS squared away and sell it?
I need to do some cosmetic work on my MKIII. Also need to rebuild the pitch trim system. Needs a new cable. The old system we designed 28 years ago held together for a lot of hours, around 3400.00, the first time around.
Next time you are through the Heart of Dixie, stop by for a cup of coffee.
From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Pfatchantz
Sent: Friday, October 19, 2018 10:18 PM
Subject: RE: urethane fuel (??) line
Meetooo....
George H.
Firestar
Mesick, Michigan
Titus, Alabama |
