Connecting rod cyl # 5 is bent, can the cylinder be replace
Viperdoc
PostPosted: Wed Nov 21, 2018 6:16 pm    Post subject: Connecting rod cyl # 5 is bent, can the cylinder be replace Reply with quote
On Nov 20, 2018, at 3:51 PM, George S. Coy <george.coy(at)gmail.com (george.coy(at)gmail.com)> wrote:
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> <![endif]--> <![endif]-->
I presume you mean can the link rod be replaced. Yes, but it is not fun. If it is a high time engine, you should consider overhaul.
George Coy
From: owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) [mailto:owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)] On Behalf Of Serge Svoysky
Sent: Tuesday, November 20, 2018 4:08 PM
Subject: Connecting rod cyl # 5 is bent, can the cylinder be replaced or engine OH is a must?
<image001.jpg>
Viperdoc
Viperdoc
PostPosted: Wed Nov 21, 2018 6:18 pm    Post subject: Connecting rod cyl # 5 is bent, can the cylinder be replace Reply with quote
Rebuild.Doc
On Nov 20, 2018, at 5:11 PM, Mark Davis <markdavis(at)wbsnet.org (markdavis(at)wbsnet.org)> wrote:
How did it get bent? Prop strike?  Hydraulic lock?
Mark Davis
N44YK
Sent: Tuesday, November 20, 2018 2:08 PM
<image001.jpg>
Viperdoc
