donjohnston
Posted: Mon Sep 17, 2018 12:10 pm Post subject: Battery Minder connector |
I have a Battery Minder with the connector provided. I would like to change to something I can mount to the airframe that will allow connecting with one hand.
Anyone have any suggestions?
113.04 KB |
10026 Time(s) |
ashleysc(at)broadstripe.n Guest
Posted: Mon Sep 17, 2018 7:40 pm Post subject: Battery Minder connector |
Hi Don;
I have the same connector. I cut an oval hole in the fuselage just ahead of the firewall, but just behind the cowling. I let the connector protrude outside slightly. I held it in place with an aluminum bracket that squeezes the connector body. The bracket is J-shaped with two holes. One hole is 5/32" for a rivet. The other is 3/16" for a #10-32 bolt that goes through two thicknesses of aluminum at the U-shaped end. Both fasteners go through the firewall. The bolt squeezes the connector and holds it firmly in place.
Cheers! Stu.
eschlanser
Posted: Tue Sep 18, 2018 7:53 am Post subject: Re: Battery Minder connector |
I have a Schauer CM6A charger feeding an Odessey PC680 through an aux power (cigarette lighter) socket through an adapter plug such as this:
https://www.atbatt.com/battery-tender-081-0069-5-cigarette-adapter-quick-disconnect-black/?gclid=EAIaIQobChMI9vGZwvDE3QIVjbXACh3p6A47EAQYEiABEgJiY_D_BwE
The aux power socket is wired to the always hot battery bus. Thus I can charge the battery even when the main bus is off.
This Schauer charger is set to deliver a 4 amp charge to a depleted battery. It then automatically tapers down to a maintenance level. Works for me. Maybe this would work for you if you have an aux power socket.
Eric
16.41 KB |
9991 Time(s) |
ronaldcox
moosepileit
Posted: Thu Sep 27, 2018 8:08 am Post subject: Re: Battery Minder connector |
BatteryMINDer EZC-01 Universal Flush-Mountable EZ Connector - with 4 Mounting Screws
$15 on Amazon
32.58 KB |
9946 Time(s) |
donjohnston
Posted: Sat Sep 29, 2018 4:26 am Post subject: Re: Battery Minder connector |
| moosepileit wrote: | BatteryMINDer EZC-01 Universal Flush-Mountable EZ Connector - with 4 Mounting Screws
$15 on Amazon |
Bingo!!!
Thanks Moose!
