Aluminium Fuel Pipe
ward.t(at)xtra.co.nz
PostPosted: Sat Sep 01, 2018 1:26 am    Post subject: Aluminium Fuel Pipe Reply with quote
Hi All,
I have 6 Aluminium Fuel Pipes left over from the last batch. I am not intending to order any more so if builders/owners require one please contact me. I can bring them to post in the USA, Canada and UK if necessary. £25 plus postage.
See UK Europa Club website for details about the pipe.
Tim
Tim Ward
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand
Mob +64 210640221
robzeelenberg1(at)gmail.c
PostPosted: Sat Sep 01, 2018 2:03 am    Post subject: Aluminium Fuel Pipe Reply with quote
Hi Tim , i'm in need for a AL fuel filler pipe for my Classic monowheel Europa # 157 PH-POP , flying since  sept 1999 ,in Holland (Netherlands) please send one if possible ? what are the costs of the pipe and sending ? (give me your bank acc.?)
with kind regards Rob Zeelenberg .
Op za 1 sep. 2018 11:28 schreef Tim Ward <ward.t(at)xtra.co.nz (ward.t(at)xtra.co.nz)>:
--> Europa-List message posted by: Tim Ward <ward.t(at)xtra.co.nz (ward.t(at)xtra.co.nz)>
Hi All,
Tim
Tim Ward
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand
Mob +64 210640221
pa-List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?Europa-List
WIKI -
PostPosted: Sat Sep 01, 2018 3:26 am    Post subject: Aluminium Fuel Pipe Reply with quote
Hi Rob,Thanks for your email. Just confirm this pipe is for the XS model or Monowheel with the Mod to the fuel intake with larger baggage capacity. The fuel flows through the side intake, down the cobra white plastic and then the pipe, I supply.
See photo.
If that is what you want then I need your address and I will charge you through PayPal £25 plus postage.
Kind regards,
Tim
[img]cid:FAC15BDA-2C13-4154-B257-F0FACA3C2531[/img]
Tim Ward12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand
Mob +64 210640221
On 1/09/2018, at 7:01 AM, Rob Zeelenberg <robzeelenberg1(at)gmail.com (robzeelenberg1(at)gmail.com)> wrote:
Hi All,
Tim
Tim Ward
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand
Mob +64 210640221
WIKI -
 Filesize:  73.6 KB
 Viewed:  14836 Time(s)
PostPosted: Sat Sep 01, 2018 3:34 am    Post subject: Aluminium Fuel Pipe Reply with quote
Hi Tim , thnx for the quick response ,but no I still have the original standard fuelinlet on the back of the fuselage so I have to look further .. but thanks
kind regards Rob .
Op za 1 sep. 2018 13:28 schreef Tim Ward <ward.t(at)xtra.co.nz (ward.t(at)xtra.co.nz)>:
See photo.
Kind regards,
Tim
Fendalton,
Christchurch, 8052
New Zealand
Mob +64 210640221
Hi All,
Tim
Tim Ward
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand
Mob +64 210640221
WIKI -
 Filesize:  73.6 KB
tennant
PostPosted: Tue Sep 04, 2018 2:01 am    Post subject: Re: Aluminium Fuel Pipe Reply with quote
Hi Rob,
I have 50 x 1,0 mm 6061T6 Alu tube in stock. You would only Need a fuel resistant Silicone or rubber 90 & 45 deg bends and any smells disappear.
Let me know if it is a possibility for you.
Barry
Barry Tennant
D-EHBT
At EDLM - Germany
PostPosted: Tue Sep 04, 2018 11:49 am    Post subject: Aluminium Fuel Pipe Reply with quote
Hi Europaeans,
Only got two left which I can bring with me to post to the USA, or Canada, and then on to the UK next week.
This is most likely the last batch I will do.
UK LAA approved. £25 plus postage
See UK Europa Club website for details under:
https://www.theeuropaclub.org/the-club/sales-and-spares-member-adverts/xs-aluminium-fuel-bend
Tim
[img]cid:0C635558-4372-4DCB-8F11-995DE6577FD8[/img]
[img]cid:296F69F0-577E-413B-8E4D-9FF9C7DCE84F[/img]
Fendalton,
Christchurch, 8052
New Zealand
Mob +64 210640221
 Filesize:  57.85 KB
 Viewed:  14788 Time(s)
 Filesize:  70.89 KB
PostPosted: Thu Sep 06, 2018 11:16 am    Post subject: Aluminium Fuel Pipe Reply with quote
that is certainly a good solution , do you have any idea where to get the 90 &45 silicon bends ?kind regards Rob .
Op di 4 sep. 2018 12:04 schreef tennant <barrington.tennant(at)gmail.com (barrington.tennant(at)gmail.com)>:
--> Europa-List message posted by: "tennant" <barrington.tennant(at)gmail.com (barrington.tennant(at)gmail.com)>
Hi Rob,
Barry
Barry Tennant
D-EHBT
At EDLM  -  Germany
http://forums.matronics.com/viewtopic.php?p=482900#482900
WIKI -
Corinthian
PostPosted: Thu Sep 06, 2018 11:22 am    Post subject: Aluminium Fuel Pipe Reply with quote
Try Merlin Motorsports.
On 6 Sep 2018, at 11:03, Rob Zeelenberg <robzeelenberg1(at)gmail.com (robzeelenberg1(at)gmail.com)> wrote:
Hi Rob,
Barry
Barry Tennant
D-EHBT
At EDLM - Germany
WIKI -
Roland
PostPosted: Thu Sep 06, 2018 11:05 pm    Post subject: Re: Aluminium Fuel Pipe Reply with quote
I got a 60° elbow silicone fuel resistant hose with 15cm legs manufactured from Samco (bought via Merlin Motorsports) to replace the original rubber hose. The legs can be cut to length if need be. It costs 67,96 GBP + VAT + shipping.
This way you avoid additional connections. The fuel smell in the Cockpit was gone.
Roland
PH-ZTI
XS TG 914
tennant
PostPosted: Fri Sep 07, 2018 4:48 am    Post subject: Re: Aluminium Fuel Pipe Reply with quote
It seems that Merlin is the only distributor!
Barry
Barry Tennant
D-EHBT
At EDLM - Germany
tennant
PostPosted: Fri Sep 07, 2018 4:53 am    Post subject: Re: Aluminium Fuel Pipe Reply with quote
When I did mine about 10 years ago I used a stainless steel pipe and I just cut the bends from the original pipe and used them, but I think it is time for me to change them as they are quite old now, so I will be buying the elbows from Merlin as well.
Barry
Barry Tennant
D-EHBT
At EDLM - Germany
Paul M 383
PostPosted: Fri Sep 07, 2018 11:14 am    Post subject: Aluminium Fuel Pipe Reply with quote
Europa also supply a silicone elbow (FS16) as part of Mod 79 (http://www.europa-aircraft.co.uk/updates/mods.php) or (http://www.europa-aircraft.co.uk/upload/Modification%20Bulletin%20No%2079%20(Issue%2003).pdf)
It's about GBP46 + shipping + VAT... might be worth a call...?
 Filesize:  81 KB
 Viewed:  14732 Time(s)
zwakie
PostPosted: Sun Oct 07, 2018 1:10 am    Post subject: Re: Aluminium Fuel Pipe Reply with quote
Hi Roland, do you pictures available that demonstrate how these are fitted? I guess you meant that you can do with the rubber joining? If so, I really like that approach.
What's the ID of the hose that you ordered? Reason for asking is that you mention 15cm legs, where Merlin's website only shows that length of 102mm ID, so I'm a bit puzzled now. How much length of legs did you actually end up in your install?
BR, Marcel.
PS How are you getting along with your fuel tank?
Marcel Zwakenberg
Europa XS TG || 912ULS || PH-SBR
