Firestar Re-Configure Project
Goto page 1, 2  Next
victorbravo(at)sbcglobal.
PostPosted: Thu Aug 30, 2018 10:34 pm    Post subject: Firestar Re-Configure Project Reply with quote
Kolbers, I made a decision today to go ahead with most of the collective advice and consensus of the Kolb List, and I began disassembling the oil system in order to re-configure it similar to Larry C's HKS Firestar.
After speaking with John H, Larry C, and e-mail corrrespondence with several others, plus all the public discussion, I must admit that the changes I made (oil cooler venting above the wing, perhaps the exhaust pipes blocking the propeller in-flow) are very likely the cause of my aircraft's poor performance.
So I am going to re-mount the oil cooler down lower on the cage away from the wing, and I'm going to move the oil tank lower underneath the wing, and these two things will allow me to make a full airfoil-shaped center gap seal/cover like Larry's (and most of the Rotax Kolbs).
I am also going to go back and try to install the original HKS exhaust system and muffler, to have the exhaust pipes out of the airflow path to the propeller. This will require me to make a new engine mount plate, moving the engine forward several inches. That of course will help the CG move a little forward, even though the aircraft is safely flyable at its current CG.
I have no doubt the Kolb List will thoroughly enjoy watching me eat this much crow... Smile Smile Smile
I'll will probably be down for a month or two in order to get all this done correctly.
Bill Berle
On Thu, 8/30/18, Jerry-TS-MkII <12flybellaire(at)gmail.com> wrote:
Subject: Re: First short XC Flight and Slow Cruise Speed
Date: Thursday, August 30, 2018, 12:38 PM
"Jerry-TS-MkII" <12flybellaire(at)gmail.com>
Well that info may save me from asking
them about engines which they paid to have returned to the
factory.  I hadn't done my quota of stupid things that
day, when I bought it.  Let me know if your carbs fall
off and you need two new ones.  I'd just like to find
out what, if any of the components are the same as the new
700s.  It might help me recover some of my small
investment. Maybe I'll remove the PRU and bolt it onto a GEO
metro, or a Subie conversion?  I did see a choice
engine at Oshkosh. direct drive, with Harley cylinders on a
half VW case:
http://www.vwaircraftengineconversions.com/the-javelina-twin-cylinder-95-hp-12-vw-aircraft-engine-conversion.html
more info at: (starting at 6:24 or so
into the video).. first half good too!
https://www.youtube.com/watch?v=QdubY_EAi1w
http://forums.matronics.com/viewtopic.php?p=482811#482811
The Kolb-List Email Forum -
Navigator to browse
List Un/Subscription,
7-Day Browse, Chat, FAQ,
    - MATRONICS WEB FORUMS -
via the Web Forums!
    - NEW MATRONICS LIST WIKI -
Email List Wiki!
  - List Contribution Web Site -
support!
gdhelton(at)gmail.com
PostPosted: Fri Aug 31, 2018 2:19 am    Post subject: Firestar Re-Configure Project Reply with quote
No crow here Bill. I would just like for you to be safe and have some fun. It is and experiment.
George H.
Firestar
Mesick, Michigan
On Aug 31, 2018, at 2:33 AM, Bill Berle <victorbravo(at)sbcglobal.net> wrote:
Bill Berle
www.ezflaphandle.com - safety & performance upgrade for light aircraft
www.grantstar.net - winning proposals for non-profit and for-profit entities
half VW case:
Navigator to browse
via the Web Forums!
Email List Wiki!
support!
Richard Pike
PostPosted: Fri Aug 31, 2018 4:47 am    Post subject: Re: Firestar Re-Configure Project Reply with quote
All we want is for you to have a good flying airplane that you enjoy. Crow? Don't even go there, because some of us will have to go with you.
Because we originally put a free air 277 on our Firefly instead of a fan cooled, we created a number of problems for ourselves. Since Rotax hasn't made any 277 parts in probably 25 years, we had to buy two more engines to get the right parts to make one good one.
The fan cooled engine has a completely different and much larger mag end crankcase, so we had to make up new taller motor mounts, finally got the engine mounted yesterday. Started to wire it up, and discovered why the radio wouldn't work right, so now we build a new wiring harness. Then I need to redo the pulley setup for the recoil starter, & still haven't started repairing the broken nose bowl. Need to better shock mount the panel, and make a new, bigger windshield, the old one was too small anyway.
Consequently, it will probably be November before I'm allowed to wear this shirt...
 Filesize:  217.3 KB
 Viewed:  25225 Time(s)
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Rex Rodebush
PostPosted: Fri Aug 31, 2018 7:53 am    Post subject: Re: Firestar Re-Configure Project Reply with quote
Don't worry about any crow. I think everybody on this list has had to rework something on their plane at one time or another. I modified at least half a dozen things (or more) on mine.
Jerry-TS-MkII
PostPosted: Fri Aug 31, 2018 7:07 pm    Post subject: Re: Firestar Re-Configure Project Reply with quote
Bill...
It's too bad that you are facing some rework, after already spending a lot of effort.. but like everyone else on here, I'd agree with your decision to make the changes. And there is no one on here throwing stones. Your topics generated a lot of thought and good idea sharing along the way. And that may save the next guy from having a similar situation. Will be just as interesting to know how much those changes improve the performance!
All good,
Jerry
lcottrell
PostPosted: Fri Aug 31, 2018 7:26 pm    Post subject: Firestar Re-Configure Project Reply with quote
Jerry, I've Liked every thing that you have contributed to this subject. You are also right that there is no castigation in every ones attempt to help Bill. Every one would just like for him to enjoy his project as much as we do ours. I understand and believe that this list is a bit different from most of them in that there is no "guru" on this one, just a bunch of guy's that are willing to help.Larry
On Fri, Aug 31, 2018 at 9:09 PM Jerry-TS-MkII <12flybellaire(at)gmail.com (12flybellaire(at)gmail.com)> wrote:
--> Kolb-List message posted by: "Jerry-TS-MkII" <12flybellaire(at)gmail.com (12flybellaire(at)gmail.com)>
Bill...
All good,
Jerry
http://forums.matronics.com/viewtopic.php?p=482834#482834
WIKI -
Jerry-TS-MkII
PostPosted: Fri Aug 31, 2018 9:56 pm    Post subject: Re: Firestar Re-Configure Project Reply with quote
Larry,
Thanks for the compliment. But clearly everyone qualifies for their contributions as well. Whether it's a R/C club, or EAA group, or this forum.. there is typically some hierarchy, of those who have been around for a long time, or who post a lot. Looking at the index numbers, there are a lot more readers than those who post replies, but that shows how much interest is generated.. sharing ideas.
Before long, I might need to ask how much dust a Kolb can collect before the gear legs break, but hopefully I'll rectify that soon, and move forward more quickly as I continue to revive a old Twinstar. I'm the newbie to Kolbs.. but there is some truth that airplanes are airplanes. It really has been a wonderful life time of working on, and building lots of projects, including various planes. So I've always felt that well learned lessons should be shared.
DIY?? "Well.. first you get 2 gallons of gumption..." LOL
Or that other famous phrase: The first 90% of a project takes 90% of the time. The last 10% takes ANOTHER 90% of the time!
Thanks for all of your beautiful videos!!
Jerry
neilsenrm(at)gmail.com
PostPosted: Sat Sep 01, 2018 1:52 pm    Post subject: Firestar Re-Configure Project Reply with quote
Bill
Please do these changes one at a time so you and we will know what had the largest effect.
I'm still going to bet that these changes are going to be minor. Also attempt do the changes in a way that would allow you to go back if you don't like the change.
I think the biggest thing that is making your plane slow is the increased fuselage area that the wind is seeing from the tail high and nose down attitude. It really doesn't matter who or where the change was made. As you probably know most changes have other effects and lowering the wing angle of attack and the tail may increase takeoff and landing speeds.
I used to have a muffler on my VW. Maybe my 4 into 1 system makes it quiet but I had NO increased noise at cruise throttle by just having a straight pipe system and I gained a 100 RPM on takeoff. My airplane is noisy but not from exhaust noise.
Someone suggested raising the engine, don't do that. One version of my VW MKIIIC had a high thrust line and it was dangerous. The lower thrust line the better and safer your Kolb will fly.
Rick Neilsen
Redrive VW Powered MKIIIC
On Fri, Aug 31, 2018 at 2:36 AM Bill Berle <victorbravo(at)sbcglobal.net (victorbravo(at)sbcglobal.net)> wrote:
--> Kolb-List message posted by: Bill Berle <victorbravo(at)sbcglobal.net (victorbravo(at)sbcglobal.net)>
Bill Berle
On Thu, 8/30/18, Jerry-TS-MkII <12flybellaire(at)gmail.com (12flybellaire(at)gmail.com)> wrote:
 half VW case:
 Navigator to browse
 via the Web Forums!
 Email List Wiki!
 support!
WIKI -
PostPosted: Sat Sep 01, 2018 2:49 pm    Post subject: Firestar Re-Configure Project Reply with quote
My fuselage is hanging under the wing at the same angle as everyone else as far as I can see??? Kolb gave me the Should be the same drag... I could lower the wing incidence but that is redesigning the Firestar.
Sent from my Samsung Captivate(tm) on AT&T
Rick Neilsen <neilsenrm(at)gmail.com> wrote:
Bill
largest effect.
from exhaust noise.
Rick Neilsen
On Fri, Aug 31, 2018 at 2:36 AM Bill Berle <victorbravo(at)sbcglobal.net>
> current CG.
> done correctly.
> Bill Berle
> for-profit entities
> To: kolb-list(at)matronics.com
> half VW case:
> Navigator to browse
> via the Web Forums!
> Email List Wiki!
> support!
Richard Pike
PostPosted: Sat Sep 01, 2018 2:55 pm    Post subject: Re: Firestar Re-Configure Project Reply with quote
Rick Neilsen
Rick, do you remember how many inches above the main tube your thrust line was? Since we have gone to the fan-cooled 277 instead of the free air 277, we have had to raise the engine 2" to clear the top motor mount tube with the fan housing. Earlier in this thread it was mentioned that Bryan said not to go over 36". Given that the 277 makes a lot less thrust than what anybody else is using on a Kolb, I expect it to be manageable, but you do have me curious.
Richard Pike
Kingsport, TN 3TN0
Jerry-TS-MkII
PostPosted: Sat Sep 01, 2018 3:16 pm    Post subject: Re: Firestar Re-Configure Project Reply with quote
Just sharing information about my comments to raise the engine.
One of the VERY LAST things which Bill mentioned about his machine modifications, was the venting of his oil cooler from high pressure to the upper wing surface. And that he noticed some unusual swirling air patterns. (NOT good!)
While the lift distribution on most (whole) airfoils is greater towards the front.. the rear still lifts. But that does not include wings that effectively have a large hole in the center, or worse ones which have high pressure air injected into that area. So if the aft 2/3rds normally generates some of the lift.. it's probably not there in Bills plane. How wide is/was that upset? I suggested yarn indicators and a camera to observe it in flight. Worse, if the forward part of the wing IS lifting, then the resulting pitching moment, would point it nose up, much more than a normal whole airfoil and therefore excess down stick forces could be explained, if not expected.
If you take a heavy plane, and then reduce the lift (with a hole, as he produced by accident), the stall speed will go up (his did), the angle of attack will need to go up, where the lift AND drag are both increased. That means most of the thrust is used just maintaining the normal flight straight and level (his was really doing all it could considering his WOT indicated speed reports. And Bill reported that the rate of climb was poor, also a indicator of lacking sufficient "excess HP" over straight and level.
At first I thought he might have a CG-overweight-trim issue. He said his thrust line was lower than the normal 503 installations. I would assume everyone would consider a factory 503 FS II to have a proper/safe thrust line. I wasn't recommending going beyond/above that.. only back to where it is comparable. His prop is currently lower than most. To raise it slightly would have helped, IF it had been a "trim or CG" issue under power. CLEARLY.. the wing fix should be his high priority.. before other changes are made. It may be the only improvement that is truly required. Any time drag can be reduced.. without cost or weight penalty, it's a good thing. I too suggested he loose the muffler! LOL
Jerry
PostPosted: Sat Sep 01, 2018 4:47 pm    Post subject: Firestar Re-Configure Project Reply with quote
Bill
If your wing is hanging like everyone else you wouldn't need to raise the horizontal stabilizer so far above the boom tube.
Rick Neilsen
On Sat, Sep 1, 2018 at 6:51 PM Bill <victorbravo(at)sbcglobal.net (victorbravo(at)sbcglobal.net)> wrote:
--> Kolb-List message posted by: Bill <victorbravo(at)sbcglobal.net (victorbravo(at)sbcglobal.net)>
Rick Neilsen <neilsenrm(at)gmail.com (neilsenrm(at)gmail.com)> wrote:
>Bill
>largest effect.
>from exhaust noise.
>Rick Neilsen
>> current CG.
>> done correctly.
>> Bill Berle
>> for-profit entities
>>  To: kolb-list(at)matronics.com (kolb-list(at)matronics.com)
>>  half VW case:
>>  Read this topic online here:
>>  Navigator to browse
>>  via the Web Forums!
>>  Email List Wiki!
>>  support!
WIKI -
PostPosted: Sun Sep 02, 2018 12:15 am    Post subject: Firestar Re-Configure Project Reply with quote
On Sat, 9/1/18, Rick Neilsen <neilsenrm(at)gmail.com> wrote:
Bill If your wing is hanging like everyone else you wouldn't need to raise the horizontal stabilizer so far above the boom tube.
How exactly can I tell if the fuselage and wing are or are not like everyone else's Kolb?
The only information I have on that subject is one single measurement, gotten directly from Kolb (also on the plans), and my aircraft is within 1/32" of that measurement they gave me.
If my aircraft closely meets their measurement, and if my wing is still not correctly aligned to the fuselage, then by definition it MUST mean that EITHER my fuselage is damaged, OR that Kolb welded mine together incorrectly.
Either of these things are of course possible, but let's assume Kolb welded my fuselage correctly, and that the problem on my aircraft must be damage to the steel tube cage that I have not yet discovered. How do I verify that?
How and where do I measure the correct angle of wing alignment/incidence, OTHER than the one simple measurement I got from Kolb (which is also shown on the plans)?
Bill Berle
racerjerry
PostPosted: Sun Sep 02, 2018 1:24 am    Post subject: Re: Firestar Re-Configure Project Reply with quote
Maybe we should be comparing the difference between wing incidence angle to boom tube angle. By comparing Bill's plane with other Firestar II's, that should answer the question about the possibility of too high an angle of attack possibly causing nose-low flight and slowing the airplane.
Jerry King
ceengland7(at)gmail.com
PostPosted: Sun Sep 02, 2018 5:03 am    Post subject: Firestar Re-Configure Project Reply with quote
Bill,
A few more thoughts. I agree about the 'one thing at a time' advice. Though the oil cooler and center section would obviously need to happen at the same time. Earlier, I missed the oil cooler configuration/center section issue. That, combined with the oil spatter pattern on top of the wing, sounds like a major clue. If you've got spanwise (or even reversed) flow over a significant area, you could be killing lift over a *lot* of the wing. The remaining area must work harder (higher angle of attack) which increases drag. As a FWIW, I've got an old Twinstar with a fan-cooled 503. The builder removed the fan and built an exit duct on the engine that ends just forward of the prop. Cooling courtesy of Bernoulli. Possible alternative for your oil cooler.
Another thought is about engine power. The fuel flow you quoted sounds like you were probably making around 40 hp; possibly a lot less at cruise. Those very long pipes and muffler of unknown restriction may be removing a lot of power. Most engine mfgrs quote power figures in optimized conditions, and engines rarely make as much power in real world installations. Your exhaust may be robbing a lot of power, fighting exhaust flow instead of enhancing it like a set of tuned length pipes.
But I'd be fixing the wing gap first. Hopefully, you have enough hose length to just rotate the cooler 90 degrees & allow closing the top of the wing.
Charlie
baberdk
PostPosted: Sun Sep 02, 2018 8:00 am    Post subject: Firestar Re-Configure Project Reply with quote
I have thought about the CoG problem. It is a range that the plane will operate throughout. But when the plane is in the air, the center of lift of a wing is 25%. I think that is the point that the plane rotates about when flying, not the CoG. When you raise or lower the tail you are changing the angle of attack of the wing by rotating the plane around the angle of lift. It becomes apparent that raising the tail reduces the angle of attack which also reduces the amount of lift. In my opinion, when the CoGravity is away from the CoLift you trim for the difference. The CoG will change, that is why it is a range, but the CoLift of your wing is always 25%. The easiest way to change CoG is to move the battery but moving the engine seems like it would have a larger effect although I haven't tried it. Has anyone else? An engine weighs more than a battery but the battery can have a larger moment and I'm too lazy to figure it out.
On a taildragger, we normally let the plane slow down until it quits flying. But when I see the contests to shorten the landing distance, it appears they are increasing the angle of attack above 19 degrees to the relative wind at which point the wing will stall at any speed. It should drop the plane out of the sky and then you overcome the forward inertia. The slower you can fly with the boundary layer attached to the top of the wing, the less forward inertia you have to overcome on ground contact. It's more of a bombing run than a landing in the contests, but a lot of people can't fly a taildragger because you can't flair and they are not very patient. In the contests they FLAIR.
A helicopter doesn't lose lift because the wing is rotating and producing lift all the way to the ground with no forward motion of the fuselage. The fuselage is just drag but raising or lowering the tail will change the area exposed to the stationary air along with the AoA. If we put a Kolb in a wind tunnel we could play with the elevator angle to personalize it, but I'll bet Homer wanted that wing at a certain angle of attack so he wouldn't get sued. But with an Experimental, let's have fun.
[img]cid:ii_jll1ini60[/img]
Respectfully,
Dennis Baber
Cape Coral, Fl
baberdk(at)gmail.com (baberdk(at)gmail.com)
Stay Curious
 Filesize:  21.83 KB
 Viewed:  33760 Time(s)
Rex Rodebush
PostPosted: Sun Sep 02, 2018 8:49 am    Post subject: Re: Firestar Re-Configure Project Reply with quote
Bill,
Get a digital level.
Measure the wing angle under the wing fore and aft. Take readings on each rib or alternate rib and average them.
Do the same for the motor mounts fore and aft and the tube and horizontal stabilizer.
Compare these angles to what Kolb recommends or the angles on a good firestar that hopefully someone on the list will give you.
I don't know of any other way to find out what you are dealing with. Just guessing or "I think it looks right" doesn't do it.
PostPosted: Sun Sep 02, 2018 9:11 am    Post subject: Firestar Re-Configure Project Reply with quote
Did you all know that no numbers are required, in most cases, if a Kolb is built to plans.
We checked CG on the Ultrastar by hanging the aircraft from the main spar carry through. If it was close to level it was good to go. No paperwork required. No battery to move forward or back.
My original FS had no weight and balance.
My MKIII did, but the cg was so far back on paper that it was illegal to fly. My MKIII flies pretty good. In a glide it is trimmed perfectly. Under power it takes a lot of nose up trim. That pusher prop is at the end of a long lever that naturally pushes the nose down. That's why we have nose up pitch trim. I've flown some pretty screwed up Kolbs and they flew much better than "The Mystery Ship", Bill B's FSII.
Build and configure the Kolb the way the plans call for, hang some extra long main gear legs and big ass tires and the the Kolb will fly great. The Mystery Ship has some things not built or rigged to specs. Get it back to specs and specified rigging and it will fly.
Do you think you are getting full power out of your HKS? It is a second hand engine with time on it. How do you know it is running like it should?
This thread has got to be a record for the Kolb List.
I can't fix it if I can't see it.
A helicopter produces lift most of the time until you stall the blades, just like stalling a fixed wing. They like clean, cool, dry air. They will settle with power when too much pitch is pulled in and they begin stalling. You get out of that stall by lowering the collective and pushing the nose over, hoping you have enough altitude to recover. Why are we discussing helicopters?
Short landing contestants, the pros at least, don't flare because they are at the very edge of the stall all the way to the ground. They are flared when the are making the approach to land.
Stay close to Larry Cottrell and his FSII. It flies great with an HKS and big tires. Just what Bill B is looking for as an off field aircraft.
Somewhere on a mountain near Morgan, Utah.
[image: image.png]
Respectfully,
Dennis Baber
Cape Coral, Fl
Stay Curious
PostPosted: Sun Sep 02, 2018 10:47 am    Post subject: Firestar Re-Configure Project Reply with quote
Kolbers:
Forgot to qualify my comments in my previous message below.
What I write on the Kolb List is in no way meant to encourage anyone to do as I do. My methods of building, repairing, rigging, and flying Kolb aircraft are mostly unconventional by other's standards. I have lived and still live an unconventional life style. I spent time in the US Army Special Forces as an EM and an officer, in peace and war. I have always been somewhat of a maverick. I guess that life style never wears off.
If you want to use any of the info I share, feel free to do it. I don't encourage anyone to do so. What works for me may not work for you. What I share does work for me and has been learned through many years and hours of building, flying, making mistakes, tearing up Kolbs, experimenting, and working until I get something that works well for me.
So please don't go do something because I said I do it.
I'm celebrating 50 years as a rotary wing and fixed wing flight time. I've been able to survive so far. Don't intend to change that.
Between East Canyon and Morgan, Utah.
> [image: image.png]
> Respectfully,
> Dennis Baber
> Cape Coral, Fl
> Stay Curious
Rex Rodebush
PostPosted: Sun Sep 02, 2018 11:09 am    Post subject: Re: Firestar Re-Configure Project Reply with quote
John,
You said "Did you all know that no numbers are required, in most cases, if a Kolb is built to plans".
Mine didn't work out that way. I initally set the wings per measurement per the plans. At final assembly I called Brian for the angles as there had been a lot of discussion on the list at that time regarding wing angles. I had to redrill the front wing attachment and use the "reverse" back u-joint with washers to get the correct angles. (see pictures) The plane has flown great so I'm sure the angles are good.
Maybe I screwed up the measurements the first time? Don't know.
My point is that if you measure the angles you know exactly what you have.
 Filesize:  117.12 KB
 Viewed:  25134 Time(s)
 Filesize:  118.02 KB
Goto page 1, 2  Next
Page 1 of 2
