Can You PLEASE help Me Find a CHINT NP4 Switch (or equivalen
billhuntersemail(at)gmail
PostPosted: Sat Jul 28, 2018 11:09 am    Post subject: Can You PLEASE help Me Find a CHINT NP4 Switch (or equivalen Reply with quote
Sorry for the slightly off topic post (however this is for a machine installed inside my airplane hangar).
I am looking for a pushbutton switch to replace the broken one on my hydraulic lift.
It's a push button momentary contact on single pole single throw switch.  The diameter of the hole in the panel is 0.894 inches / 22.72 MM.
The switch that broke is labeled CHNT NP4 and it has other numbers on it such as GB140 48.5 and it's a 10 amp switch.
It is a switch that you push and hold in the button and then a relay closes to energize the electric motor that moves the hydraulic pump.
Again, sorry about the off-topic post however I've spent 30 minutes on the Google  with no success but I'm sure there's a guy on this forum that will recognize this switch immediately and know exactly where to find one (or one that will work).
Thanks!!!
Bill Hunter
 Filesize:  544.99 KB
 Viewed:  3842 Time(s)
alec(at)alecmyers.com
PostPosted: Sat Jul 28, 2018 11:22 am    Post subject: Can You PLEASE help Me Find a CHINT NP4 Switch (or equivalen Reply with quote
https://www.google.ca/search?q=chint+np4+switch
There are about a million options...
On Jul 28, 2018, at 20:08, William Hunter <billhuntersemail(at)gmail.com (billhuntersemail(at)gmail.com)> wrote:
Thanks!!!
Bill Hunter
<Screenshot_2018-07-28-11-54-56~2.png>
PostPosted: Sat Jul 28, 2018 3:47 pm    Post subject: Re: Can You PLEASE help Me Find a CHINT NP4 Switch (or equiv Reply with quote
A search for Chint NP4 gave these:
https://www.aliexpress.com/item/CHINT-Button-Switch-Since-Reset-NP4-11BN-Flat-Button-Switch-Reset-Switch-Button-Normally-Open-Often/32828826215.html
http://www.usbreaker.com/products/products.php
https://tinyurl.com/Allied-SW
Joe Gores
