Posted: Fri Jul 27, 2018 7:52 am Post subject: Sun Visor user reports and comparison |
I originally installed the sun visors from Aviation Tech Products in my RV10 back in 2011. They worked well. There is a full range of adjustment including protection from sun on the side windows when needed. The only problem I ran into over time is that the mounting required periodic tightening of the mounting bolt. After 6+ years, the passenger side visor tended to droop during rough field landings (my home base is a bumpy grass field) and could no longer be tightened enough to keep it in place during those landings.
As a 1,000 hour present, I decided to give my '10 a set of Rosen Visors simply to fix the occasional droop. That seems like a nit of a problem but after 1,000 hours, cockpit comfort and convenience issues tend to stand out. The more expensive Rosen Visor is a more robust product in terms of the their mounting hardware and design. Most notably, the Rosen uses 2 bolts to mount to the airframe where the Aviation Tech Visor uses 1 bolt. This, along with the rest of the mounting and adjustment hardware, looks like it will make a difference over time.
My conclusion at this point is that both products are good values and would recommend either. You get what you pay for in the margins of durability.
- The Aviation Tech product is reasonably priced and works quite well. No regrets here. I feel like I got good service with only a minor complaint after 6 years of flawless service. They are well built, well designed and easy to adjust as the sun moves around.
- The Rosen product is premium priced and works quite well. I am confident that I will get good service for the life of the airframe. They are solidly built, well designed and easy to adjust as the sun moves around.
Just thought I'd share.
Now I'm trying to figure out whether dropping $$$ on the newer Bose ANRs is a worthy gift for my wife and me. We have 4 of the old units - battery powered in the rear, bus powered (or battery) in the front. They all work well but a little more noise reduction would always be welcomed.
Bill "still loving the best airplane I'll ever own" Watson
www.avast.com [url=#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2] [/url]
Kelly McMullen
Posted: Fri Jul 27, 2018 5:31 pm Post subject: Sun Visor user reports and comparison |
If you are talking Bose X to Bose A20, yes it is worth it, at least for front seat. I think a few shops still offer trade-ins on the X model
I traded my with mypilotshop.com a couple years ago. Can't comment on the new in the ear models, but the Bose rep at OSH said you get more noise reduction with the A20s.
| Quote: | | Sent from my IBM-360 main frame |
On Fri, Jul 27, 2018 at 8:50 AM, Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)> wrote:
www.avast.com
[url=#m_-9010087143114339674_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2] [/url]
A&P/IA, EAA Tech Counselor
KCHD |
greghale
Joined: 10 Jan 2007 Posts: 91 Location: Tulsa, Oklahoma
Posted: Thu Aug 23, 2018 12:39 pm Post subject: Re: Sun Visor user reports and comparison |
I installed the Rosen 310 sunvisor. It has the outside corner beveled to allow the sunvisor to go up to the windshield. They also slide and can be positioned anyway you like. I attached mine to the upper corner of the door frame. If you have an overhead console, they should clear.
Greg...
3.21 KB |
10290 Time(s) |
_________________ Greg Hale rv10 -- N210KH
www.nwacaptain.com |
AirMike
Posted: Tue Sep 04, 2018 8:41 pm Post subject: Sun Visor user reports and comparison |
I had Rosens in my RV10 and they were great. One sore point though is that they scratched the windscreen when one of my bozo buddys slapped them around roughly. To preclude that happening again, I put a dab of pro-seal along the edge that could hit the window - no more problem. Highly recommend the Rosens, but hit them with the dab of pro-seal when you install them. It looks ugly on the new units, but it works.
_________________ See you OSH '18
Q/B - sold. |
Posted: Wed Sep 05, 2018 5:40 am Post subject: Sun Visor user reports and comparison |
I'm thinking an armed ejection seat for the Bozo...
.. but thanks, will do that.
On 9/5/2018 12:41 AM, AirMike wrote:
See you OSH '18
Q/B - sold.
