lsvance54
Posted: Sun Jul 15, 2018 1:03 pm Post subject: Woodcomp Propeller Overhaul |
I just completed the LSRM-A repairman course and found a Service Bulletin on the Woodcomp Propeller that I did not previously know about.
Apparently, my 2006 Allegro 2000 should have been grounded for a propeller overhaul as of 2012. The Woodcomp Klassic 160 has a 6 year/ 950 hour TBO.
Anyone have a U.S. source for overhaul? Is there an alternate prop that has a better TBO or longer age limit?
[/list]
| | - The Matronics Allegro-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Allegro-List |
_________________ Scott
N25017 |
Brian Carpenter
Posted: Sun Jul 15, 2018 1:19 pm Post subject: Woodcomp Propeller Overhaul |
I would encourage you to communicate with Doug at Allegro USA.. He would be the one that would know how to respond to this question.
Sent from my Brian's
iPhone
| Quote: | On Jul 15, 2018, at 2:03 PM, lsvance54 <lsvance(at)comcast.net> wrote:
[/list]
Scott
N25017
http://forums.matronics.com/viewtopic.php?p=481651#481651
_________________ BRIAN N3081X |
N456TS
Posted: Mon Jul 16, 2018 4:12 pm Post subject: Re: Woodcomp Propeller Overhaul |
| lsvance54 wrote: | I just completed the LSRM-A repairman course and found a Service Bulletin on the Woodcomp Propeller that I did not previously know about.
[/list] |
As you know, you're NOT limited to specific age requirements. It can be evaluated on-condition and signed off by you.
_________________ N456TS |
N456TS
Posted: Mon Jul 16, 2018 5:58 pm Post subject: Re: Woodcomp Propeller Overhaul |
| lsvance54 wrote: |
> Sir,
> I have a SLSA Allegro 2000. If I were flying experimental, I believe you
> are correct. I could then evaluate and sign off.
> Had a conversation with Light Sport Guru recently from OKC (FAA). First
> thing he asked me was why I'm not already Experimental!
> How am I NOT age limited as an SLSA?
> Thanks!
> L. Scott Vance |
I refer you to the Willette letter. As you might know, the FAA legal
department interprets their regulations. This interpretation become
the FAA's official position on a subject unless the FAA is taken to
court and a judge disagrees.
The short of it is that the FAA is always above the manufacturer. The manufacturer can't over-extend their authority. They also can't stop you from using alternative methods acceptable to the administrator, such as on-condition inspection. I've attached the letter.
Doug will also refer you to the same.
You can perform an on-condition inspection on an S-LSA and an E-LSA. This is a practice acceptable to the administrator and is absolutely the norm. I've worked on several Allegros. I don't believe any of them had replaced their prop simply due to the bulletin.
Best regards,
Bradley Pearce
willette-dodgecenteraviation-legal-interpretation.pdf |
91.37 KB |
1205 Time(s) |
