TR-1 IO-240 Prince prop Spinner crack
damiller47
PostPosted: Sun Jul 01, 2018 6:44 am    Post subject: TR-1 IO-240 Prince prop Spinner crack Reply with quote
N660C, OC's plane, has been cracking spinners. Do any of you more experienced folks have any idea what may cause this?
 Filesize:  110.33 KB
 Viewed:  8303 Time(s)
Danny Miller
EAA Lifetime 647062
Aerospace Engineer
Technical Counselor
Flight Advisor
A&P
President
EAA Chapter 186
http://eaa186.org/
ftyoder(at)yoderbuilt.com
PostPosted: Sun Jul 01, 2018 8:22 am    Post subject: TR-1 IO-240 Prince prop Spinner crack Reply with quote
What spinner is on the plane? The original kit came with a fiberglass
spinner. I believe OC was using a Prince prop which I am using but I changed
to an aluminum spinner with a forward bulkhead and have had no problem. The
original FG spinner did not have a forward bulkhead and would go into
vibration once in awhile which was irritating but it didn't crack.
Tim
damiller47
PostPosted: Sun Jul 01, 2018 10:38 am    Post subject: Re: TR-1 IO-240 Prince prop Spinner crack Reply with quote
The FG spinner cracked so I put on the aluminum one pictured but it had no forward bulkhead. Any idea where I can get another one ... with the forward bulkhead?
Danny Miller
EAA Lifetime 647062
Aerospace Engineer
Technical Counselor
Flight Advisor
A&P
President
EAA Chapter 186
http://eaa186.org/
PostPosted: Sun Jul 01, 2018 11:17 am    Post subject: TR-1 IO-240 Prince prop Spinner crack Reply with quote
I ordered mine from Aircraft Spruce, you need to give them the prop hub
thickness.
Tim
