wa0ysf(at)gmail.com Guest
Posted: Mon Jul 02, 2018 5:17 am Post subject: IVO prop inflight adjustable problem |
Is anyone out there flying a 582 with an IVO Prop in flight adjustable ultralight prop?
The electric motor on mine has failed twice now, the motor goes open, no continuity.
I sent it in for repair the first time and it lasted about two flights and failed again with the same problem.
Is anyone else having this problem?
I have a Kitfox 3 with a 582 engine and an E gear box with 2.62 to 1 gear ratio.Ā 1150 hours on the plane.
Help!
Harold McConnell
NE North Dakota
Sent from Mail for Windows 10
malpass
Joined: 27 Aug 2007 Posts: 39 Location: Marietta, Georgia
Posted: Mon Jul 02, 2018 8:29 am Post subject: IVO prop inflight adjustable problem |
I have a good motor for ivo 3 blade. I took mine off to make it a legal sport pilot arrangement. Let me know if you want it. I guarantee it to work.
Bill
_________________ kitfox III w/ 582 greyhead |
franicaza(at)yahoo.com.mx Guest
Posted: Mon Jul 02, 2018 10:32 am Post subject: IVO prop inflight adjustable problem |
Hi Harold,
I“ve used IVO prop (Medium, Patriot and ultralight) in flight adjustable, for many years, in a Kitfox S6 a Vans RV-12 both with a Rotax 912S, and a Drifter with a Rotax 582. I consider it“s a good system and a reasonable price but they haven“t solved the problem with the electric motor. I“ve changed it so many times and I may tell you that it“s the fact I want to change my prop. I“m so tired to call them to Ca. so many times.
Last November a group of friend and myself went to Baja California and of four with IVO prop, three had problems with the electric motor, the same reason that you say. Very bad luck. When I travel far I always carry one on board.
Francisco Icaza
Mexico City
El lunes, 2 de julio de 2018 8:26:20 GMT-5, Harold McConnell <wa0ysf(at)gmail.com> escribió:
I have a Kitfox 3 with a 582 engine and an E gear box with 2.62 to 1 gear ratio. 1150 hours on the plane.
Help!
Harold McConnell
NE North Dakota
