Evolution of Wire (Correction)
PostPosted: Sat Apr 28, 2018 8:26 pm    Post subject: Evolution of Wire (Correction) Reply with quote
. . . . . . . . . . . . . The 22759 wire
was export controlled so we were leaning toward
Spec 55 when Lear negotiated the export license
and Teflon became the insulation of choice.
Correction. TEFZEL. We looked at Teflon
but not very hard. Excellent temperature ratings
but very expensive. Teflon extruded onto
the strands at such high temperatures that
you had to have silver plated strands.
Further, Teflon was softer and would cold-flow
under the pressure a too tight a cable tie.
kenryan
PostPosted: Sun Apr 29, 2018 7:07 am    Post subject: Evolution of Wire (Correction) Reply with quote
Why is some Tefzel wire super stiff (like that purchased from Aircraft Spruce) while other Tefzel wire is much more flexible (like that purchased from Stein Air)?
On Sat, Apr 28, 2018 at 8:25 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
ceengland7(at)gmail.com
PostPosted: Sun Apr 29, 2018 7:42 am    Post subject: Evolution of Wire (Correction) Reply with quote
Are the numbers printed on the wire *exactly* the same? If memory serves, many months ago I was trolling ebay for deals on milspec wire & in the process, found various numbers that all were Tefzel insulation, but some had thicker insulation (larger overall diameter) than others of the same gauge. I wish I could quote the numbers, but I failed to document what I found.
Charlie
On Sun, Apr 29, 2018 at 10:04 AM, Ken Ryan <keninalaska(at)gmail.com (keninalaska(at)gmail.com)> wrote:
kenryan
PostPosted: Sun Apr 29, 2018 8:45 am    Post subject: Evolution of Wire (Correction) Reply with quote
M22759/16 -- some I have bought (white) is very stiff while other (colors) is noticeably more flexible.
On Sun, Apr 29, 2018 at 7:41 AM, Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
Charlie
alec(at)alecmyers.com
PostPosted: Sun Apr 29, 2018 10:07 am    Post subject: Evolution of Wire (Correction) Reply with quote
22759/18 is like /16 but “thin wall”, if I recall.
On Apr 29, 2018, at 11:41, Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
Charlie
kjashton(at)vnet.net
PostPosted: Sun Apr 29, 2018 10:50 am    Post subject: Evolution of Wire (Correction) Reply with quote
Here is a handy chart of wire species. You can google the coating abbreviations or the part numbers for more info
-Kent
On Apr 29, 2018, at 11:41 AM, Charlie England <ceengland7(at)gmail.com> wrote:
Wire16878-22759.pdf
 Filename:  Wire16878-22759.pdf
 Filesize:  66.38 KB
 Downloaded:  850 Time(s)
PostPosted: Sun Apr 29, 2018 1:24 pm    Post subject: Evolution of Wire (Correction) Reply with quote
On Sun, Apr 29, 2018 at 7:41 AM, Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote: Are the numbers printed on the wire *exactly* the same? If memory serves, many months ago I was trolling ebay for deals on milspec wire & in the process, found various numbers that all were Tefzel insulation, but some had thicker insulation (larger overall diameter) than others of the same gauge. I wish I could quote the numbers, but I failed to document what I found.
there is a catalog at: https://goo.gl/ZfNq9T
In this document, you will find that 22759 has
about 90+ 'slash' numbers that define variations
on the theme for this class of wire.
There are other mil-spec numbers describing
wire that is entirely suited to our tasks.
I am mystified that products in a particular
/number would demonstrate significant variations . . .
unless the variations are a feature not defined
in the root specification . . . flexibility may
indeed be one. But materials, construction and
dimensions should be consistent to the catalog
description.
