EGT location
Jack B Hart
PostPosted: Sat Apr 28, 2018 3:32 pm    Post subject: EGT location Reply with quote
Kolbers,
I have a new engine and it came without an EGT tap.
What is the rule of thumb for EGT placement?
Jack B. Hart FF004
Winchester, IN
Jack B Hart FFoo4
Winchester, IN
PostPosted: Sat Apr 28, 2018 5:12 pm    Post subject: EGT location Reply with quote
I'd contact the manufacturer and get their specs for placement.
I don't think there is a standard location for all engines.
From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Jack Hart
Sent: Saturday, April 28, 2018 6:31 PM
Subject: EGT location
Kolbers,
Jack B. Hart FF004
Winchester, IN
Richard Pike
PostPosted: Sat Apr 28, 2018 7:12 pm    Post subject: Re: EGT location Reply with quote
Digging into the 2005 CPS catalog, on page 86 of their Rotax Info pages, I found this info on EGT probes starting at the bottom of the 2nd column and getting pertinent in the middle of the center column, and if I read it right (?) the probe ought to be 4 inches from the piston wall.
The 2nd image is a blowup of the pertinent section.
FWIW, I went out to the hangar and the factory installed EGT bosses on the 582 are 1 5/8" away from the end of the exhaust port flanges, which would probably put them 4" out from the piston wall, so that agrees.
As Beauford used to say; "Worth what ye paid fer it." I miss him.
 Filesize:  434.67 KB
 Viewed:  5000 Time(s)
 Filesize:  265.06 KB
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
