SD-8 Alternator Feed 30A Inline Fuse Location
Airdog77
PostPosted: Sat Apr 21, 2018 7:14 am    Post subject: SD-8 Alternator Feed 30A Inline Fuse Location Reply with quote
Bob,
In your response on the Z13 Battery Bus Protection question in a very recent post, you reminded us that
Recall that circuit protection is for WIRES . . . and that the protective device is installed as close as practical to the SOURCE of energy that puts the wire at risk.
A friend of mine asked me a question on my Z-13/8 configuration that stumped me, so I thought I'd ask you.
In keeping in line with your statement above, in Z-13/8 why is the inline 30A fuse for the SD-8 wire connection from the battery contactor to the SD-8's S704-1 relay placed within 6 inches or less from the battery contactor, when the SD-8 is the source of energy?
Wade
Airdog
Wade Parton
Building Long-EZ N916WP
www.longezpush.com
PostPosted: Sat Apr 21, 2018 7:24 am    Post subject: Re: SD-8 Alternator Feed 30A Inline Fuse Location Reply with quote
There are two sources of energy, the battery and SD-8. The SD-8 is self current limiting. It can put out perhaps 10 amps at most. Its output does not need to be fused. The battery can put out hundreds of amps and possibly do lots of damage. Placing the fuse near the battery will minimize the danger.
Joe Gores
ceengland7(at)gmail.com
PostPosted: Sat Apr 21, 2018 7:25 am    Post subject: SD-8 Alternator Feed 30A Inline Fuse Location Reply with quote
On 4/21/2018 10:14 AM, Airdog77 wrote:
Bob,
Wade
I'm not Bob, but an alternator wire should be big enough to handle
everything an alternator can throw at it, meaning the alternator can't
damage it. But... The battery *can* damage it, so the protection is at
the potential source of the damage.
That help?
Airdog77
PostPosted: Sat Apr 21, 2018 7:36 am    Post subject: Re: SD-8 Alternator Feed 30A Inline Fuse Location Reply with quote
Makes all the sense in the world.... now that you guys explained it!!
Crystal clear. Always good to learn something new!
Thanks Joe & Charlie!
Wade
Airdog
Wade Parton
www.longezpush.com
