BruceClemens
Posted: Sat Jun 23, 2018 11:10 am Post subject: Bicycle Tubing as a Source for Aircraft? |
Isn't bicycle tubing some sort of chrome moly? Would there be uses for bicycle tubing in homebuilt aircraft? Perhaps not in critical areas but other less- critical applications?
Cheap and readily available.
I did a search on this board for uses of bicycle tubing but nothing came up.
Would appreciate your opinions and answers!
| - The Matronics Homebuilt-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Homebuilt-List |
glen
Joined: 17 Sep 2013 Posts: 186 Location: Oregon Coast
Posted: Sat Jun 23, 2018 2:05 pm Post subject: Bicycle Tubing as a Source for Aircraft? |
What alloy?
Quote: | On Jun 23, 2018, at 12:10 PM, BruceClemens <clemensfam3(at)sbcglobal.net> wrote:
http://forums.matronics.com/viewtopic.php?p=481149#481149
BruceClemens
Posted: Sat Jun 23, 2018 3:29 pm Post subject: Re: Bicycle Tubing as a Source for Aircraft? |
[quote="glen"]What alloy?
Don't know, Glen. That's why I'm asking. Of course that's something we need to know for specific uses, but, if we don't know, can we use it for non critical uses and feel safe?
Have any members used bicycle tubes for things on their airplanes?
It is cheap and readily available.
gerry.vandyk(at)eastlink. Guest
Posted: Sat Jun 23, 2018 6:18 pm Post subject: Bicycle Tubing as a Source for Aircraft? |
What parts would you consider to be 'non-critical'? I have only my own
project to judge by, but I can't think of anything off hand that I would
consider replacing with 'other' material. Primary structure, not a
chance. Control system, nope. Proabably weld tabs. Can't think that
any significant savings would be realized. Then again, I had plenty of
off cuts from building the primary structure, it covered pretty much all
the other parts anyway.
Gerry
BruceClemens
Posted: Sun Jun 24, 2018 3:04 pm Post subject: Re: Bicycle Tubing as a Source for Aircraft? |
gerry.vandyk(at)eastlink. wrote: | What parts would you consider to be 'non-critical'? I have only my own
consider replacing with 'other' material. Then again, I had plenty of
Gerry
Thank you, Gerry. You make much sense. With regard to "non-critical", I am thinking of things that do not deal with aerodynamic loads, or are load bearing components of the structure of the aircraft, of course.
You make perfect sense saying that one who builds a tubular airframe will have plenty of off-cuts to make ancillary components.
But, in my case, I am building an all-wood Peit. There are few metal tubes. Most seem to be in what I would call less-critical (e.g. non load bearing) uses, such as the control group including the sticks, the tube they connect to and the rudder bars.
I agree, I would never use unknown metal in the other metal parts such as engine mount, landing gear, gussets, or control hinges.
But in an Experimental aircraft is there really a need to use and pay for specific metals in parts that will perform flawlessly with at least as much certainty as the expensive stuff?
I just finished reading and saving a treatise about using used motorcycle wheels on a Piet landing gear. This, I think, is representative of the spirit of homebuilt experimental aircraft.
Some folks say that they would never fly with someone who used non aircraft-specific components on their product. But that would preclude them from flying with many very good homebuilders.
Thanks!
glen
Posted: Sun Jun 24, 2018 3:51 pm Post subject: Bicycle Tubing as a Source for Aircraft? |
All I can add is food for thought. No one can say that substitution does work. Do you really want to be the first mouse? I’d rather b the second mouse
Quote: | On Jun 24, 2018, at 4:04 PM, BruceClemens <clemensfam3(at)sbcglobal.net> wrote:
> Gerry
Thanks!
http://forums.matronics.com/viewtopic.php?p=481177#481177
lyleapgmc
Posted: Mon Jun 25, 2018 7:12 pm Post subject: Bicycle Tubing as a Source for Aircraft? |
Not necessarily chrome moly but mild steel has been used for aircraft
structure before. One issue with bicycle tubing is that it is often
much thicker than aircraft tubing, thus a weight problem. There are
often few straight sections of tubing in a bicycle. No length is long
enough to be useful for framing an aircraft.
Best thing is to check the price of tubing suitable for aircraft.
