SD-20 Troubleshooting
billhuntersemail(at)gmail
PostPosted: Sat Mar 24, 2018 3:45 pm    Post subject: SD-20 Troubleshooting Reply with quote
Hi All,
I was hoping I could talk you into helping me troubleshoot an SD-20 with a LR3C-14 Voltage Regulator.
Prior to this issue the alternator would produce 14.4 volts and about 10 amsp in cruise flight and other times when the engine is turning quickly.  The isolated bus that is powered by this system is now showing 12.2 volts and 4.5 amps and then slowly the volts on that bus keep dropping so it is obvious that the alternator is not charging.
The bus that it is powering is small and the only items being powered in cruise flight are the following (amps listed are the absolute max that the appliance will be pulling):
VOLT REG SENSE   2          LR3C-14 Voltage Regulator BUS VOLTAGE SENSE
VOLT REG FIELD    5          VOLTAGE REGULATOR FIELD
Dynon SV-1000          5          SV-D1000 10" SKYVIEW DISPLAY
SV COM RADIO       5          SV-COM-425             0.2amp RCV  3 amp XMT
SV-AP SERVO          5          SV-AP SERVO          Pitch servo 2 amps when MAX torque
        Roll servo 2 amps when MAX torque
SV-AP POWER         3          SV-AP UNIT
Can someone please provide me with some troubleshooting advice?
Cheers!!!
Bill  Hunter
PostPosted: Sat Mar 24, 2018 7:01 pm    Post subject: Re: SD-20 Troubleshooting Reply with quote
Do you have the B and C trouble shooting manual?
http://www.bandc.aero/pdfs/BC410-H_Technical_Manual.pdf
There is also a troubleshooting guide in the LR3C Manual.
http://www.bandc.aero/pdfs/LR3C_Installation_Manual.pdf#page=8
Joe Gores
PostPosted: Sat Mar 24, 2018 7:09 pm    Post subject: SD-20 Troubleshooting Reply with quote
Thanks Joe... greatly appreciated
Bill Hunter
On Sat, Mar 24, 2018, 20:06 user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
Joe Gores
http://forums.matronics.com/viewtopic.php?p=478857#478857
Mauledriver(at)nc.rr.com
PostPosted: Tue Mar 27, 2018 11:00 am    Post subject: SD-20 Troubleshooting Reply with quote
I just went through the troubleshooting for that same configuration.  After doing the procedure for the LR3, one finding didn't match the spec.  I reviewed the results with B&C and they were able to tell me with confidence the LR3 failed (1,000 hours) - could be repaired or new.   All good now.
Bill Hunter
Joe Gores
www.avast.com [url=#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2] [/url]
trigo(at)mail.telepac.pt
PostPosted: Tue Mar 27, 2018 2:32 pm    Post subject: SD-20 Troubleshooting Reply with quote
So now you are Bill problem solved Watson, right?
Couldn’t resist
Carlos
Enviado do meu iPhone
No dia 27/03/2018, às 19:59, Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)> escreveu:
Bill Hunter
Joe Gores
www.avast.com
PostPosted: Fri Mar 30, 2018 5:07 am    Post subject: SD-20 Troubleshooting Reply with quote
I'm not keeping up the tradition.... I'll have to work on that.
Couldn’t resist
Carlos
Bill Hunter
Joe Gores
www.avast.com
