willydewey
Joined: 24 Sep 2014 Posts: 53 Location: Guildford Surrey United Kingdom
Posted: Thu Mar 15, 2018 7:24 am Post subject: iLevil & Replacement Fuel Feed |
Hi Guys
I have bought an iLevil 3SW and would appreciate advice where to fit it avoiding or minimising magnetic effects.. It could go on or under the parcel shelf on my 914 trigear or in the roofspace between the doors, I am just not sure hence the plea for advice.
We have just completed the LAA mod for the replacement rubber at the lower end of the polypropylene filler using the specified bent aluminium tube and the fluorsilicate connecting pieces It was a simple process, however the original rubber elbow was found to be in perfect condition with no signs of deterioration whatsover. Another £85 wasted but well worth the inspection.
_________________ Give a wise man knowledge and he will be yet wiser |
clivesutton
Posted: Thu Mar 15, 2018 8:12 am Post subject: Re: iLevil & Replacement Fuel Feed |
Hi Bill,
I've put mine behind the RH panel on top of the tunnel and on top of a foam/GF fabricated 'wedge' to bring it level in flight. Actually there is an article in with Tony Wickens that i expect will be published in the EF. Despite 'seeing' the UC frame, it seems to work fine so far. I've tried to attach a pic to this message that illustrates . . .
Clive
2.72 MB |
3762 Time(s) |
