Dynon Pitot Heat Warning with MGL EFIS
art(at)zemon.name
PostPosted: Mon Mar 12, 2018 4:06 am    Post subject: Dynon Pitot Heat Warning with MGL EFIS Reply with quote
Folks,
I am installing a Dynon heated pitot tube. The controller has a pin which gets grounded if the heater is turned on and fails. This is supposed to drive a warning lamp. See "pitot heat warn" on the attached diagram.
I want to replace the pitot heat warn lamp with an indicator on my MGL EFIS. The EFIS has eight analog inputs (see A1 through A8 on page 6 of the attached iBOX V1 installation manual) and also has four balanced analog inputs (see 1+,1- through 4+,4-) on page 7.
This would be easy for me if INST-4-G from the Dynon controller was either grounded or at some positive voltage. But if I understand correctly, that wire is either grounded or open. How do I hook this to my EFIS?
    -- Art Z.
https://CheerfulCurmudgeon.com/"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel
pitot.pdf
 Filename:  pitot.pdf
 Filesize:  28.13 KB
 Downloaded:  998 Time(s)
iBOX_V1_installation_manual.pdf
 Filename:  iBOX_V1_installation_manual.pdf
 Filesize:  250.25 KB
 Downloaded:  1084 Time(s)
PostPosted: Mon Mar 12, 2018 4:59 am    Post subject: Re: Dynon Pitot Heat Warning with MGL EFIS Reply with quote
Connect a pull-up resistor, perhaps 1K Ω or more, between a positive source and the Dynon alarm wire.
Joe Gores
art(at)zemon.name
PostPosted: Mon Mar 12, 2018 5:33 am    Post subject: Dynon Pitot Heat Warning with MGL EFIS Reply with quote
Joe,
What do I connect to the EFIS?
    -- Art Z.
On Mon, Mar 12, 2018 at 7:59 AM, user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
PostPosted: Mon Mar 12, 2018 7:11 am    Post subject: Re: Dynon Pitot Heat Warning with MGL EFIS Reply with quote
A picture is worth a thousand words.
 Filesize:  81.66 KB
 Viewed:  12633 Time(s)
Joe Gores
art(at)zemon.name
PostPosted: Mon Mar 12, 2018 8:13 am    Post subject: Dynon Pitot Heat Warning with MGL EFIS Reply with quote
Joe,
Got it. That'll work. Thank you.
    -- Art Z.
On Mon, Mar 12, 2018 at 10:11 AM, user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
PostPosted: Mon Mar 12, 2018 12:46 pm    Post subject: Re: Dynon Pitot Heat Warning with MGL EFIS Reply with quote
I would try it without the pull-up resistor first. It might not be needed.
Joe Gores
BARRY CHECK 6
PostPosted: Mon Mar 12, 2018 2:02 pm    Post subject: Dynon Pitot Heat Warning with MGL EFIS Reply with quote
How would you do that if the reference is ground?
On Monday, March 12, 2018, user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
Joe Gores
http://forums.matronics.com/viewtopic.php?p=478626#478626
Electric-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
WIKI -
lank">http://wiki.matronics.com
Barry
"Chop'd Liver"
If you wash your hands before you go to the bathroom you may have the makings of a Crew Chief.
