M14P bent connecting rod
richard.goode(at)russiana
PostPosted: Fri Feb 09, 2018 5:46 am    Post subject: M14P bent connecting rod Reply with quote
What typically happens is that because of the bending, the connecting rod become shorter and therefore pulls the piston further out of the cylinder. The oil control ring is close to the bottom of the piston, and will then jump out of its groove and attempt to prevent the piston going back up. Inevitably the ring then breaks, and a very obvious sign is high oil consumption and smoke appearing from that one cylinder; and plug fouling. And this can be established using a TDC tool, demonstrating that the one piston is not going as far up the cylinder as the others. But you don't have a lot of time before the rod will break, and then it flails around, typically damaging other cylinders!
Richard Goode Aerobatics
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
Tel:  +44 (0) 1544 340120
Fax: +44 (0) 1544 340129
www.russianaeros.com
From: Mark Pennington [mailto:pennington.construction.inc.1(at)gmail.com]
Sent: 09 February 2018 12:18
To: Richard Goode <richard.goode(at)russianaeros.com>
Subject: M14P bent connecting rod
Richard
I fly a CJ with the M14P conversion and seeing that makes things pretty obvious how important pulling the prop through every time you start the engine really is.
With an engine in that condition would there be any tell-tale signs of a bent rod that could be noticed while operating the plane? Or is this a "silent" problem that just fails later.
I am new owner, only about a year and a half so any info would be appreciated.
Mark Pennington
Richmond VA
Virus-free. www.avast.com
believed to be clean.
 Filesize:  350 Bytes
 Viewed:  5711 Time(s)
Lancer
PostPosted: Mon Mar 05, 2018 10:15 pm    Post subject: Re: M14P bent connecting rod Reply with quote
With the Housai Engine, when the rod bends to the point where the lower oil control ring pops out the bottom of the cylinder, the crankshaft counterweights start milling the bottom off of the piston contaminating the inside of the engine and the oil system with loads of tiny shards of aluminum. I'd say the M14 would also do the same.
You can run but you can't hide
PostPosted: Tue Mar 06, 2018 2:22 am    Post subject: M14P bent connecting rod Reply with quote
I have no experience of the Chinese engine, but have seen serious engine
failure quite often with the M 14, and what seems to happen is that the oil
control ring breaks as a consequence of the bent and therefore somewhat
shorter connecting rod; the engine continues to run but with extremely high
oil consumption and after a few hours if no one has had the sense to examine
things, then the connecting rod breaks and causes mayhem. But I've never
seen - or more to the point noticed - damage on the bottom of the piston.
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
