Need a device to send 12volts when all 3 green lights are l
ceengland7(at)gmail.com
PostPosted: Thu Jan 11, 2018 11:56 am    Post subject: Need a device to send 12volts when all 3 green lights are l Reply with quote
On 1/11/2018 1:37 PM, Jeffrey W. Skiba wrote:
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> <![endif]--> <![endif]-->
Below is the landing gear circuit,  I need a device or build one that can use the 12volts coming from the gear down and locked switches and only send 12 volts to another device[for testing a led] IF ALL 3 lights (gear down and locked)
I thought use 3 NPN transistors in series but it seems on my test, if I supply 12 volts to the base of the npn it still lights the led (leak though ?) with no voltage on anything else
I am using figure two of these examples
http://www.rason.org/Projects/transwit/transwit.htm
IDEAS ?
Look here:
https://www.google.com/search?q=3+input+and+gate+truth+table&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwikuoCK2NDYAhVM1oMKHUrVDZgQsAQIKA&biw=1920&bih=987#imgrc=GMoqi5mBR2TtpM:
Note that a quad input AND gate might be easier to find, and you can use it as a 3 input by tying the 4th input high.
PostPosted: Thu Jan 11, 2018 12:03 pm    Post subject: Need a device to send 12volts when all 3 green lights are l Reply with quote
IDEAS ?
Look here:
Here's one that works on 12V, & you get 2 spare devices in the package:
http://www.ti.com/lit/ds/symlink/cd4082b.pdf
PostPosted: Fri Jan 12, 2018 11:42 am    Post subject: Need a device to send 12volts when all 3 green lights are l Reply with quote
On 1/12/2018 1:30 PM, Robert L. Nuckolls, III wrote:
At 05:03 PM 1/11/2018, you wrote:
Then I would lose each gear indication.  This is for an audio alert device input if the gear is not down and locked (all 3)
From: owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com) [ mailto:owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com)] On Behalf Of Robert L. Nuckolls, III
Sent: Thursday, January 11, 2018 3:04 PM
Subject: Re: Need a device to send 12volts when all 3 green lights are light
  Okay, how about something like this:
[img]cid:part2.43A68B38.1440408D(at)gmail.com[/img]
What's wrong with using a CMOS 3 input AND gate (linked in an earlier email)?
 Filesize:  60.26 KB
 Viewed:  2920 Time(s)
