Starting coil wire
j_sagastuy(at)yahoo.es
PostPosted: Tue Jan 09, 2018 2:28 pm    Post subject: Starting coil wire Reply with quote
Hello
I cannot start the engine and I have checked the wire between the Starting coil and the left magneto, as Dennis explained in others messages.
The end of the wire seems to be burned. I have checked the continuity and it is ok but not touching the spring.
Could you give me any advice? Is it possible to buy a new one wire complete? the spring must be replaced?
Best regards
Jesús Sagastuy
EC-IAQ
 Filesize:  33.13 KB
 Viewed:  1958 Time(s)
 Filesize:  24.27 KB
