skyking76t(at)verizon.net Guest
Posted: Sun Jan 07, 2018 5:17 pm Post subject: Left inside main Gear Door |
Anybody have a left side inside main landing gear door p/n XL 229.501-01.05 for sale? This is the door attached to the fuselage. No corrosion or damage. Just need door only
Tony
| | - The Matronics L29-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?L29-List |
taylor527(at)att.net Guest
Posted: Sun Jan 07, 2018 5:39 pm Post subject: Left inside main Gear Door |
Hi Tony,I have new or used,new has to be drilled and fitted
Pete
On Jan 7, 2018, at 5:17 PM, Anthony Royal <skyking76t(at)verizon.net (skyking76t(at)verizon.net)> wrote:
| Quote: | Anybody have a left side inside main landing gear door p/n XL 229.501-01.05 for sale? This is the door attached to the fuselage. No corrosion or damage. Just need door only
Tony
Dawg
Posted: Sun Jan 07, 2018 6:48 pm Post subject: Left inside main Gear Door |
Why?
| Quote: | On Jan 7, 2018, at 18:37, Taylor <taylor527(at)att.net (taylor527(at)att.net)> wrote:
PeteSent from my iPad
Tony
_________________ Dawg |
Posted: Sun Jan 07, 2018 6:55 pm Post subject: Left inside main Gear Door |
Bottom of door corroded off up about one inch and broke off. Skin, reinforcement, and c-channel support. Could probably fix but may be cheaper to buy a door by the time I buy everything plus time. Right side was repaired, I assume by the military, by cutting the corner off and patching but the underlying [parts were still good.
On Sunday, January 7, 2018 9:50 PM, William Geipel <l129bs(at)gmail.com> wrote:
Why?
Tony
Dawg
Posted: Sun Jan 07, 2018 6:58 pm Post subject: Left inside main Gear Door |
do we need to drill drain holes on the bottom?
| Quote: | On Jan 7, 2018, at 19:55, Anthony Royal <skyking76t(at)verizon.net (skyking76t(at)verizon.net)> wrote:
On Sunday, January 7, 2018 9:50 PM, William Geipel <l129bs(at)gmail.com (l129bs(at)gmail.com)> wrote:
Why?
Tony
Posted: Sun Jan 07, 2018 7:24 pm Post subject: Left inside main Gear Door |
No way to do that. On the very bottom tip of the gear door, just below the jack pad, you have the outer skin, behind the skin is a flat reinforcement plate, and a c-channel backer. The c-channel was fine but the skin itself looked like when magnesium corrodes. It just fell apart when I touched it. The plane stays in a hangar too and the door has good paint on it.. The reinforcement was almost in as bad a shape. The skin is riveted to the reinforcement and the reinforcement rivet holes had cracked thru. I cut out the bad skin but would have to do a lot of small rivets to attach a new patch and probably have to look at some type of automotive panel adhesive to help attach the patch to what's left of the reinforcement plate.....paper thin. Be much easier and probably cheaper to install and fit a new or used door. If it was just the outer skin,like on the right gear door, the repair would be a breeze.
I believe this is the end that gets hit when you pull the jack out if not careful. I've never hit it though.
On Sunday, January 7, 2018 9:59 PM, William Geipel <l129bs(at)gmail.com> wrote:
Why?
Tony
N777ZE
Posted: Tue Jan 09, 2018 3:21 pm Post subject: Re: Left inside main Gear Door |
I might have one in my basement, see attached photos Might be willing to trade for other spare parts or $$
1.88 MB |
12782 Time(s) |
1.61 MB |
12782 Time(s) |
Posted: Tue Jan 09, 2018 3:29 pm Post subject: Left inside main Gear Door |
Thanks Josh for responding. Already have one coming from another owner but appreciate it all the same.
On Tuesday, January 9, 2018 6:23 PM, N777ZE <Piper72pilot(at)hotmail.com> wrote:
--> L29-List message posted by: "N777ZE" <Piper72pilot(at)hotmail.com (Piper72pilot(at)hotmail.com)>
http://forums.matronics.com/viewtopic.php?p=477202#477202
http://forums.matronics.com//files/21c78bfc_708c_49ce_8ec8_13f549b6619a_169.jpeg
http://forums.matronics.com//files/e2867b42_d78b_4681_bfe3_f0a522806cfa_173.jpeg
http://w -Matt Dralle, List Admin.
