Simplest way for a go/no-go 2-Stroke Engine Temperature I
PostPosted: Wed Jan 03, 2018 9:38 am    Post subject: Simplest way for a go/no-go 2-Stroke Engine Temperature I Reply with quote
At 08:39 PM 1/2/2018, you wrote:
--> AeroElectric-List message posted by: Charlie England <ceengland7(at)gmail.com>
On 1/2/2018 12:26 PM, user9253 wrote:
Perhaps some kind of temperature switch would work?
https://www.omega.com/pptst/TSW-TT.html
Joe Gores
I like Joe's find. Still have to watch the max temp, though.
Another option uses the Analog Devices thermocouple
conditioners in a on-off switching mode.
https://goo.gl/7ufeaL
Here's a simplified schematic . . .
[img]cid:7.1.0.9.0.20180103113458.060890d8(at)aeroelectric.com.0[/img]
Instead of driving a heater control relay, one could
drive an LED indicator light directly from the
signal conditioner's output . . .
This would let you connect directly to the cylinder
head with appropriate thermocouple material.
 Filesize:  103.35 KB
 Viewed:  2463 Time(s)
