ceengland7(at)gmail.com Guest
Posted: Tue Jan 02, 2018 6:34 pm Post subject: Simplest way for a go/no-go 2-Stroke Engine Temperature Ind |
On 1/2/2018 12:26 PM, user9253 wrote:
email(at)jaredyates.com Guest
Posted: Tue Jan 02, 2018 7:18 pm Post subject: Simplest way for a go/no-go 2-Stroke Engine Temperature Ind |
I like the temperature switch very much, thanks! Now I just need a little trial and error to sort out the right temperature range.
On Tue, Jan 2, 2018 at 9:39 PM, Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
| Quote: | --> AeroElectric-List message posted by: Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)>
I like Joe's find. Still have to watch the max temp, though.
WIKI -
bob.verwey(at)gmail.com Guest
Posted: Wed Jan 03, 2018 2:42 am Post subject: Simplest way for a go/no-go 2-Stroke Engine Temperature Ind |
Joe is the operating voltage not an issue?
On 02 Jan 2018 8:33 PM, "user9253" <fransew(at)gmail.com (fransew(at)gmail.com)> wrote: | Quote: | --> AeroElectric-List message posted by: "user9253" <fransew(at)gmail.com (fransew(at)gmail.com)>
Perhaps some kind of temperature switch would work?
https://www.omega.com/pptst/TSW-TT.html
Joe Gores
http://forums.matronics.com/viewtopic.php?p=477017#477017
WIKI -
Joined: 28 Mar 2008 Posts: 1967 Location: Riley TWP Michigan
Posted: Wed Jan 03, 2018 7:26 am Post subject: Re: Simplest way for a go/no-go 2-Stroke Engine Temperature |
No, the operating voltage is not a concern. The switch is rated for 2 amps at 24 VDC. That probably equates to 3 or 4 amps at 12 volts. If an indicator lamp is chosen that uses less than 1 amp, it should be fine. The switch is available as either normally open or normally closed. There is a 50-50 chance of getting it right. The original poster probably wants the normally closed switch. Another concern is selecting the correct operating temperature. And there is the life expectancy issue when subject to the vibration of a 2 cycle engine.
_________________ Joe Gores |
yellowduckduo(at)gmail.co Guest
Posted: Wed Jan 03, 2018 8:47 am Post subject: Re: Simplest way for a go/no-go 2-Stroke Engine Temperature |
Is it feasible to mount the infrared red thermometer, suggested by YellowDuck, inside of the cockpit and use a fiber optic cable to transmit the engine heat through the firewall to the thermometer?
