graemeh
Posted: Thu Dec 21, 2017 1:45 pm Post subject: Mod 64B - Hi Top Fuselage |
Hi All
I am seeking tips and advice on completing this mod from those who have done it before me.
I hope to complete the first step of gluing the in-fill piece to the top of the canopy over the Christmas / New Year break. We are having an unusually warm summer this year so early evening I often have temps of around 22 degrees C in the garage which should be perfect for the gluing I need to do. Daytime temps are getting up to 38 degrees C so I shouldn't have any issues with the glue taking a long time to cure.
I have found a few pictures that show the work required around the windscreen and some that show the finished mod from the outside.
Can anyone point me to pictures showing the inside and the work required on the in-fill pieces (not the foam but the factory provided glass layups that I need to trim to fit).
I'd also appreciate any tips on the best way to build a support so I can tip the fuselage top on its side to work on.
Graeme
spcialeffects
Posted: Fri Dec 22, 2017 1:45 am Post subject: Re: Mod 64B - Hi Top Fuselage |
Hi Graeme. I have done this mod on my classic and have all the photos you require. By the temperatures you mention I presume your not in the UK😁. My email address is Spcialeffects(at)aol.com
Regards Frank Xuereb, kit #165……nearly flying
