dg.watts(at)talktalk.net Guest
Posted: Thu Dec 14, 2017 10:29 pm Post subject: Outrigger fork |
Hi all,
Has anybody in the UK got a spare outrigger fork or two that I could persuade them to part with?
Dave Watts
G-BXDY Classic Mono 912S Airmaster 2450 hrs
fireflier
Posted: Fri Dec 15, 2017 1:24 am Post subject: Outrigger fork |
Morning David
I will have the out rigger forks in my box of bits as I had originally bought a mono kit but built it as a tri gear.
I’m going out to the airfield this morning so will see if I can find them for you.
Kind regards
Donald
On Fri, 15/12/17, David Watts <dg.watts(at)talktalk.net> wrote:
Subject: Outrigger fork
To: "Europa Forum" <europa-list(at).com>
Date: Friday, 15 December, 2017, 6:29
Hi all,
with?
Dave Watts
hrs
The Europa-List Email Forum -
Navigator to browse
List Un/Subscription,
  - MATRONICS WEB FORUMS -
via the Web Forums!
  - NEW MATRONICS LIST WIKI -
Email List Wiki!
 - List Contribution Web Site -
support!
       Â
_________________ Fireflier |
Posted: Fri Dec 15, 2017 1:43 am Post subject: Outrigger fork |
Donald,
Thanks again for your help.
I have just had a fork snap in half at the top.
Dave
| Quote: | On 15 Dec 2017, at 09:23, DONALD CAMERON <fireflier(at)btinternet.com> wrote:
Morning David
Kind regards
Donald
Hi all,
with?
Dave Watts
hrs
Navigator to browse
via the Web Forums!
Email List Wiki!
support!
fireflier
Posted: Fri Dec 15, 2017 10:16 am Post subject: Outrigger fork |
Hi Dave
I have been at the airfield and have found all the mono parts for the outriggers. Is it just the bits that are attached to the wing brackets for the outrigger legs you require?
Donald
G-PUPY
| Quote: | On 15 Dec 2017, at 09:42, David Watts <dg.watts(at)talktalk.net> wrote:
Donald,
Dave
> Morning David
> Kind regards
> Donald
> Hi all,
> with?
> Dave Watts
> hrs
> Navigator to browse
> via the Web Forums!
> Email List Wiki!
> support!
Posted: Fri Dec 15, 2017 10:32 am Post subject: Outrigger fork |
Hi Donald,
The bit I need is the fork that actually holds the wheel at the bottom of the outrigger leg. The fork is made from thin flat steel shaped as a fork with a round tube welded on top so that it can be attached to the outrigger leg.
Dave
| Quote: | On 15 Dec 2017, at 18:15, Donald Cameron <fireflier(at)btinternet.com> wrote:
Hi Dave
Donald
G-PUPY
> Donald,
> Dave
>> Morning David
>> Kind regards
>> Donald
>> Hi all,
>> with?
>> Dave Watts
>> hrs
>> Navigator to browse
>> via the Web Forums!
>> Email List Wiki!
>> support!
fireflier
Posted: Fri Dec 15, 2017 10:38 am Post subject: Outrigger fork |
Hi Dave
Photos attached showing parts, presume from your description it
Is the middle bag.
Donald
[quote] On 15 Dec 2017, at 18:31, David Watts <dg.watts(at)talktalk.net> wrote:
Hi Donald,
118.37 KB |
7323 Time(s) |
iancook_1(at)hotmail.com Guest
Posted: Sat Dec 16, 2017 12:48 am Post subject: Outrigger fork |
Donald, If you have no use for the wheels and struts would you consider selling? My wheels are in a very poor state on G-CBHI. If you let me have account details I will forward what ever you feel appropriate.
Best Regards
Ian Cook
07912944536
On 15 Dec 2017, at 18:42, Donald Cameron <fireflier(at)btinternet.com (fireflier(at)btinternet.com)> wrote:
| Quote: | Hi Dave
Is the middle bag.
Donald
<image1.jpeg>
> On 15 Dec 2017, at 18:31, David Watts <dg.watts(at)talktalk.net (dg.watts(at)talktalk.net)> wrote:
> --> Europa-List message posted by: David Watts <dg.watts(at)talktalk.net (dg.watts(at)talktalk.net)>
> Hi Donald,
> Dave
>> On 15 Dec 2017, at 18:15, Donald Cameron <fireflier(at)btinternet.com (fireflier(at)btinternet.com)> wrote:
>> --> Europa-List message posted by: Donald Cameron <fireflier(at)btinternet.com (fireflier(at)btinternet.com)>
>> Hi Dave
>> Regards
>> Donald
>> G-PUPY
>> Sent from my iPhone
>>> On 15 Dec 2017, at 09:42, David Watts <dg.watts(at)talktalk.net (dg.watts(at)talktalk.net)> wrote:
>>> Donald,
>>> Dave
>>>> On 15 Dec 2017, at 09:23, DONALD CAMERON <fireflier(at)btinternet.com (fireflier(at)btinternet.com)> wrote:
>>>> --> Europa-List message posted by: DONALD CAMERON <fireflier(at)btinternet.com (fireflier(at)btinternet.com)>
>>>> Morning David
>>>> Kind regards
>>>> Donald
>>>> On Fri, 15/12/17, David Watts <dg.watts(at)talktalk.net (dg.watts(at)talktalk.net)> wrote:
>>>> Subject: Europa-List: Outrigger fork
>>>> Hi all,
>>>> with?
>>>> Dave Watts
>>>> hrs
>>>> Navigator to browse
>>>> via the Web Forums!
>>>> Email List Wiki!
>>>> support!
118.37 KB |
7314 Time(s) |
